Question about Zenith ZN110 Remote Control
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
I HAVE A WHITE-WESTINGHOUSE MODEL WVT11319 TV/VCR COMBO  AND I HAVE A ZENITH UNIVERSAL REMOTE MODE: (ZEN350C  -  EIA343  SK16-003) NOT SURE WHICH ONE IS THE MODEL.  CAN YOU  HELP?
Posted by REVPOIMEN on
  • 4 more comments
  • Anonymous Dec 27, 2007
    RCA REMOTE NEED CODE
  • cheymama Jan 04, 2008
    have a rca universal controll and I cant find the code
  • ajholl Jun 16, 2008
    I have a White Westinghouse tv/vcr combo wvt-113119 and need the users manual or else the code to set to a Radio Shack universal remote
  • GreyGhostCI Dec 17, 2008
    I need the univeral codes for a (May 1998) 13-inch White-Westinghouse, model WVT-11311, TV/VCR combo unit. I want to program it under "vcr" and "tv" buttons on my cable provider's standard universal remote.
    Any help is greatly appreciated ~ thank you in advance 4 ur help!
    [email protected]
  • goodsabrina Jan 09, 2009
    I have a 13 inch White Westinghouse television and a radio shack remote. Does anyone know the code to program the remote?
  • Never1toB Jan 21, 2009
    I have the tv an need to know it I can get it from vcr function to tv without a remote,, using internal setting?
Anonymous
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Posted on Feb 03, 2009
cookiebrown1
    New Friend:
I have an old 16" whitewestinghouse tv/vcr with no remote control
For some reason the timer has kicked in and it stays on about 10 seconds and turns itself off. The settings on the top of the screen are say Eject _T on the left and on the right __:__
Then on the bottom it says SP Count 0:00:0
I've had this happen once before and called someone at whitewestinghouse and they talked me through a simple fix several yrs ago. I forgot what I did and didn't write it down. I can't locate a reset button. Have tryed unplugging the set for a time hoping that would let it reset itself. The set was working with no problems until last week. Have had it for 3 yrs Manual control since remote was lost years ago.
Please advise.
Thanks Ann
Posted on Mar 29, 2011
Anonymous
Try these codes on a for universal remotes;
0154, 0179, 0451, or 0463
Posted on Jan 25, 2009
Anonymous
HAVE A RCA SYSTEMLYNKS AV CONTROL AND NEED CODE FOR WHITE WHESTINGHOUSE TV
Posted on Aug 14, 2008
Zenith TVBR1322 9 In. Combo universal code
Universal remotes will be missing key functions in these units.
Zenith (and for that matter most brands) do not make these units--about 4 companies make most of them.
Your best bet is to try to locate an original remote--Zenith(LG) or Google the model number "original remote" or even search EBAY.
Mar 21, 2012 | Zenith TVBR0922Z 9 in. Combo
Need code for a phillips universal remote for zenith tv/vcr model tvsc2040f
you can get the code automatically by pressing set button the remote then after keep pressing the volume key while you observe the tv for response once you notice any response press the set button again.now its ok.
Sep 24, 2010 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Need Universal Remote code for Zenith VCR/TV Combo TVBR19422
both together in a code or separate in brax 0226...0227...0247...0266...0288..0310..0338..0358.[0039 0252][0153 0245][0138 0279] [tvcode vcr code]
Oct 09, 2009 | Zenith TVBR1924 19 in. Combo
Remote won't detect TV
as it a learning feature if so perhaps it could learn from the original controller. i have had universal controllers in the past that are rubbish and certain makes/models can't be controlled...
May 03, 2009 | One For All URC-4021 Remote Control
Need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
Apr 15, 2009 | Zenith TVBR1342 13 in. Combo
I have no ''tv/catv'' button on my Philips universal remote
You can go here to see if you can get a new factory remote
TV Parts Universal TV Stands DLP Chips ShopJimmy or you can get a Harmony remote that will never go obsolete no matter how many times you change Tv's in the future or add components to your system
Oct 12, 2017 | Philips Magnavox Learning Universal Remote
Cant get my universal remote to work my Zenith model TVBR1922
ha i can help a little ,i also have a rca universal and same tv,vcr combo,the codes in the list rca provides
do not work ,but if you go through the code search procedure componet vcr,until the set turns off
hit enter,this will allow for power on off funtions and ch up down or number keys,also vcr functions,
but no vol, control or menu nevigation,hope this helps a little
Jan 08, 2009 | Zenith TVBR1922 19 in. Combo
Zenith Learning Remote
I am looking for the White Westinghouse sk26h240s remote codes for a Comcast universal DVR Remote control. any ideas, please email me at [email protected]
May 29, 2008 | Zenith ZEN760 Remote Control
Comcast universal remote codes don't work for zenith zhd-311 dvd/receiver/home theater
Had the hardest time finding a code for this old TV.
Posting now so that others can find this solution.
White-Westinghouse
Modle: WTV-11901
Comcast Remote Control Code 0451
Dec 22, 2007 | Zenith ZEN310 Universal Remote Control
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Zenith ZN110 Remote Control Logo
4,294 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
