BuySKU CHUNGHOP RM-139EX Remote Controlle Logo
D
Debi Seal Posted on Feb 20, 2014
I need remote Code for Seiki LED 32" TV and for my Samsung DVD Player on my Sony Universal Remote
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Oct 10, 2012
SOURCE: i need code to my universal remote for a soniq tv please
0014
2answers
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
  1. Turn on your Sony DVD player.
  2. Locate the code for your Sony DVD player in the code list provided with the universal remote.
  3. Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
  4. Enter the code for your Sony DVD player using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
  1. Turn on your Sony Bravia TV.
  2. Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
  4. Enter the code for your Sony Bravia TV using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
Using a oneforall urc-4220 universal remote but am needing a code for a seiki tv?
You should have bought a remote that was made for your television. They are $20 and called Facsimile Remotes. No programming and an exact copy of the original. Universal Remotes are so 1980 :>D
Remote Control Codes For SEIKI TVs
SEIKI TV 3 digit remote codes: 564 627 000 505 ; SEIKI TV 4 digit remote codes: 4635 3953 4794 4346 ; SEIKI TV 5 digit remote codes: 12964 13559 13560 10178
SEIKI Remote Controls for which device type?
https://www.replacementremotes.com >
SEIKI Replacement Remotes.com offers SEIKI remote controls for sale online including remote controls for TV, Blu-Ray DVD Player, TV/DVD Combo and many more.
1helpful
What is code for Seiki TV?
Search Results
    Remote Control Code for Seiki TV - TWC Community Forums
    forums.timewarnercable.com/.../Remote...Code...Seik...
    Time Warner CableJun 5, 2013 - Does anyone know the correct code to use for programming the remotecontrol with the Seiki TV? ... The one they have listed for Time Warner is a 4 digit code(0178) so it doesn't work. ... I did some research and it appears LG or Samsung codesmay work for Seiki sets.
    Seiki TV remote code - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > DISH Network Forum
    Jan 30, 2011 - 7 posts - ‎6 authors
    I purchased a 32" Seiki TV but there is no listed remote codes for this brand. Does any one know of a code that will work? Thanks.
1helpful
3answers
Need code for led tv seiki
Use Sears Code 0205 for the 40 inch LED it works!
Codes for bp59-00016 samsung remote to hook up a rca dvd player
Try the code 002 for an RCA DVD player for the BP59-00016 remote. This is the only code given for RCA DVD players for several Samsung TV universal remotes (BP59-0007 and the BP59-00016A). A manual for a TV with the BP59-00016A remote is here: http://downloadcenter.samsung.com/content/UM/200303/20030325191047000_L62A_ENG_1210.pdf .
You may need to check the age of the remote. The codes in a universal remote generally only control those devices released 6 months or more before the remote was programmed. If your RCA DVD player is newer than your remote, you may need a new remote.
I hope this helps.
7helpful
4answers
Remote code for Seiki TV 32"
The "try the Samsung codes" suggestions works. I have a ONN (Seiki) LE-24G90. The first Samsung code on the HDTV list (1019) did the trick on my Telus CISCO ST6400 remote.
Top BuySKU Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a BuySKU Televison and Video Expert? Answer questions, earn points and help others
