Question about Opteka (OP-T32X-SP350KT) for Olympus SP-350 3.2x (OPT32XSP350KT) Lens Converter
Want an oeration manual for Olympus SP350 - Opteka (OP-T32X-SP350KT) for Olympus SP-350 3.2x (OPT32XSP350KT) Lens Converter
Posted by nathanyesuda on
Anonymous
    President:
  • 919 Answers
Jensen JDD-BT43 4.5" Double Din Touch Screen manual need
I would go to the manufacturer's web page and look under Support.
Jan 16, 2015 | Jensen Car Audio & Video
Want to down load pics to my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program, such as was supplied with the camera.
Aug 09, 2010 | Opteka 3x Telephoto Lens for Olympus FE360...
Turn on my sp350 an it displays battery empty
please buy one new battery and put it then it will ok
Mar 05, 2010 | Olympus SP-350 Digital Camera
Shutter not working
is it on manual status? maybe it's not in focus.
what other stuff do work?
Aug 12, 2008 | Olympus SP-350 Digital Camera
Multic coloured screen
12b809f.jpgHere is what my pics look like. It was a progressive defect, some good pics, then these in between. Now they are all bad. I found this info below... even though the SP350 is not listed, I am going to call Olympus tomorrow. Good luck!
The camera takes blank images, or the image is distorted
  • There are a number of digital cameras models sold by Canon, Fuji, Konica-Minolta, Nikon, Olympus, Ricoh, and Sony (and possibly others) which use CCDs (image sensors) manufactured by Sony which have had a high rate of failure. Details can be found at http://www.imaging-resource.com/NEWS/1128958202.html
  • Most manufacturers will replace defective CCDs affected by this problem at no charge, regardless of warranty status. This service advisory (technically, it is not a "recall", since recalls are related to safety issues) only applies to certain models and certain serial number ranges.
  • If your camera exhibits the symptoms listed above, we recommend following the link or calling Olympus Customer Service at 800-622-6372. We do not replace the CCDs in Camedia or Digital Stylus models.
Nov 12, 2007 | Olympus SP-350 Digital Camera
OLYMPUS SP350 WONT TURN ON
Try this:
1. Remove batteries
2. Remove XD card
3. Power up without XD card and try taking a few pictures using the internal memory.
4 If this works OK I suspect it is the XD card at fault. I have had a problem with a couple of cards but most of these were when I tried reading the card using an external card reader.
5. If you have one available or can borrow one try another XD card.
I have heard that some people have had some success using the following method to restore XD card.
If you know someone with a Fuji digital camera which takes XD cards then ask them to try formatting the card in their camera for you. Maybe your local retailer will let you try this with one of their display models. I have not tried this myself.
If this fails there are some card recovery programmes on the internet - try searching for CONVAR in Google.
If the card is a Fuji card then you could try contacting Fuji as they offer a card recovery service - or at least try to recover images from corrupt cards. Contact them on the internet first to check conditions and costs.
Finally I have not had any problems with the camera since I started using lithium or rechargeable lithium batteries.
No problems that is to say other than the person pushing the shutter release.
Oct 02, 2007 | Olympus SP-350 Digital Camera
Zoom problem
hi, no way, you have to go to olympus shop. It is a case oflens assy. jamming so take it to the olympus. good luck...
Jul 27, 2006 | Olympus SP-350 Digital Camera
Opteka (OP-T32X-SP350KT) for Olympus SP-350 3.2x (OPT32XSP350KT) Lens Converter Logo
Top Opteka Cameras Experts
ADMIN Canada
ADMIN Canada
Are you an Opteka Camera Expert? Answer questions, earn points and help others
