Question about Kenmore 98702 Stacked Washer/Dryer
No drainage, Sound in Spin/Rinse Cycle
The washer does not drain. Instead, there is a clicking sound when the machine is turned on in the Spin/Rinse cycle. It still has lots of water in it because the water will not drain. The lid locks when closed during the cycle and I must rotate the cycle to Off position to unlock the lid. It agitates just fine. Why won't the machine spin or drain?
Posted by linda b on
dannydoesita
  • 777 Answers
You may have a broken pump belt, or belt may have fell off pump pulley. Another possibility is that you have a bad clog before the pump keeping water from draining. Your machine will agitate because this is a separate belt. Good Luck Friend.
Posted on Oct 14, 2017
5 Related Answers
Anonymous
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
Anonymous
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
Anonymous
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
Michael Childers
  • 240 Answers
SOURCE: No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Posted on Apr 26, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: washer stops during rinse cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I started my washer and I worked just fine then it went into an extra rinse cycle and now it won't drain or spin the door switch works I can hear it click and then a low humming sound
Turn power off, then set the machine to a spin cycle, you may need to do this several times before the door will open. Hope this helps
Oct 08, 2015 | Washing Machines
Washer Kenmore 80series Doesn't want to drain the water after it's RINSE CYCLE. No sound from motor or pump. It just stops. does it drain after the wash cycle? if it does, then I don't think it's the...
Solution for Washer Kenmore 80series stopped on SPIN CYCLE and no Drainage or motor running.
** What was stopping it to drain was the defective limit switch which when the cover lid is closed starts the spin and the drain at the same time. I jumped the wires to get my close washed and I have to replace it for security. I had to unscrew the front control panel and remove the casing that wraps around the washer to have access for the limit switch wireing harness. I cut the two black wires and joined them with a wirenut so that I was able to continue my wash and draining the water leftt over.
Sep 06, 2009 | Kenmore 22422 Top Load Washer
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer does not drain after the rinse cycle
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
May 31, 2008 | Whirlpool Washing Machines
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
155 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
