Question about Sony Handycam CCD-TRV608 Camcorder
Will not charge and I need the tape out
Hello, I lost the charger to my handycam and I really need the tape out. Is there a way I can manually take the tape out without buying another charger? Please Help
Posted by Elizabeth Maxwell on
5 Related Answers
Anonymous
  • 196 Answers
SOURCE: PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Tape stucked in the Sony DCR-PO101 NTSC Handycam
nope
Posted on Jan 21, 2008
sharmila
Sivaram Vasudevan
  • 38 Answers
SOURCE: Sony Handycam CCD-TR417E
we have this manual. Pl. email me.
Regards,
Sharmila.
Posted on Aug 26, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Need Instruction manual for sony handycam dcr-dvd
If you are looking for CCD-TRV68 instruction manual then click Sony Support and download it.
Posted on Jan 09, 2009
Anonymous
SOURCE: handycam won't play tape
i have thi problem to it is the x700 sony one :/
let me know if you have sorted the problem and tell me the soluvtion as i haven't yet :/
thankyou
Posted on Feb 24, 2010
The tape ejector is stuck up with the door closed and the tape is stuck in it and I cant get it to move down or open. What is the problem ? When I try too I get a beeping and blinking with C:32:21 on it....
Hello... The way I can get a tape unjammed on my Sony camera2.gif is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled out or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined and I don't recommend using the tape in the camera again even if you manually wind it forward past the problem area.
Hope this helps!
Apr 02, 2009 | Sony Handycam DCR-TRV310 Digital Camcorder
My handycam sony steady shot , the tape deck will not open
Try using the battery charger while attempting to eject it. The battery, although you may not know it, probably cannot supply the power needed to open the tape deck. If it makes a little Ding sound when you press the eject button, that means it is trying to eject the tape. Hope this helps!
Jan 25, 2009 | Sony Handycam CCD-TRV318 Camcorder
DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Oct 05, 2008 | Sony Handycam DCR-SR42 Camcorder
Unable to record
Battery may need replacing. Even though it takes a charge, it still may be too weak to operate the unit. Try using the power cord directly from charger. If it still fails, have unit serviced
Aug 02, 2008 | Sony Handycam CCD-TRV68 Camcorder
Lost the charger
Your manual should tell you this. I think most do not charge this way.
Feb 16, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Sony Handycam CCD-TRV608 Camcorder Logo
35 people viewed this question
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
