Sony Ericsson K750i Cellular Phone Logo
Posted on Jun 10, 2009
Flash not DONE... Pls help....
I already flash my phone but accdntly my computer automaticly turn off now my phone can't on, when i try to connect and flash again now i saw some error " PORT - OPEN " , my se k750i OS is gone pls help ..... can I reinstall OS for SE K750i....
Anonymous
Level 1:
  • Contributor 18 Answers
  • Posted on Jun 17, 2009
Anonymous
Contributor
Level 1:
Answers
18
Questions
0
Helped
9413
Points
70
Try installing firmware.
tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 • Computers & Internet
My 6600 nokia phone automatically turned off when it is on display or standby mode. I just tried to format it but it still turned off.
Hi,yr mean turn off is the phone shut off ? Or the screen blank off slowly ? If shut off ? Mayb the batt or batt connecter pro. The screen blank off slowly,even do format still same,Mayb phone's flash Ic pro, U need Sent for repair. Pls rate me if my solution useful,thx..
Feb 13, 2011 • Cell Phones
Hi all pls. my USB PTY 8 gb. My laptop not reconized. can you help! thank Frank.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Hope this helps you out.
1helpful
My phone is off each time i switch it on it just blinks and off i was told that it is a software Problem how can i solve it
you'ld have to download pretty good amount of this to do this. Follow step by step to the following procedure:
  • Downloads
    1. USB Flash Driver ( http://rapidshare.com/files/137908666/IS O-8859-1__driver.zip)
    2. XS++ 3.1 Darwin
    Please download all of these files before proceeding.
1.) Converting to CID52 (if required)If XS++ detects a DB2020 CID49 or CID51 phone, it will automatically ask if the user wants to upgrade.
CAUTION!!! If You Upgrade To CID52, You Can Not Revert Back To CID49 Or CID 51.
2) Backing up GDFS
Backing up the GDFS isn't something which necessarily has to be done when flashing firmware, but it is a very good way to ensure you don't damage your phone beyond repair.
Step 1.
Take battery out of phone and put back in (do not turn phone on). Open XS++ and click Connect. Hold down the "C" button on the phones keypad and connect the USB cable. If this is the first time you flash your phone you will need to install the Flash drivers.
Step 2.
Click on the GDFS tab
Step 3.
Click "Backup GDFS" and wait (shouldn't take more than about half a minute).
Step 4.
3) Flashing the firmware
Step 1.
Step 2.
Select the firmwares (make sure you extract them first) by clicking the "..." buttons or simply dragging the file from the explorer to the box (don't get mixed up with FS and MAIN).
Click "Flash" and wait (this takes a while, 6-7 minutes is normal).
Step 3.
Flashing is done, you can breathe now
*) Recovering from a bad flash
*WARNING* flashing a GDFS that did not originally come from that exact handset may have severe consequences. By exact handset I mean your handset, not your friends unlocked handset, YOUR HANDSET!
If a flash goes bad, two things need to be done:
1. You need to flash the firmware for the model you had before (when you did the GDFS backup), and
2. You need to restore GDFS.
For flashing follow from step 3 above. Do the GDFS restore after flashing and customizing the handset.
Step 1.
Step 2.
Step 3.
Select the backup you wish to restore. Click “Write GDFS”.
Step 4.
Done
Cant install adobe flash
hi... pls try this.. maybe your computer already have an adobe flash... pls try to uninstall if first then reinstall it.. pls follow this steps... 1. start 2. control panel 3. add/ remove program 4. click the "adobe flash" 5. remove it.. thank you very much...
About ur answer
Ther are following possiblities:
Check Virus.
Flash gone bad.
Usb is not Detecting and
for all above possibilities.
try flash on some other computer
if it detected by computer
scan it with a lattest virus remover.
otherwise your fash is no more....
2answers
Re: flash drive
First thing to do is to connect the flash drive to your computer via USb port, then if the flash drive is already detected and computer is done installing the driver for it, Just double click Mycomputer icon then you should see there the flash drive, double click on the flash drive then after that you can just copy the pics from your computer and paste it to the flash drive...
Note if the falsh drive is not detected by the computer try to connect it on a different USb port and hopefully it will be detected that time...
Hope that helps..........
2helpful
3answers
Can't switch on my Nokia 6233
my nokia 6233 mobile cant swich on my friend tell me a mobiles flash software and mobile swich on automaticly. please help me
28helpful
12answers
Motorola flash mode
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
