SOURCE: Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
SOURCE: vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
SOURCE: Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
