Auto Off is a feature that shuts down the SPD-SX automatically when it hasn't been used for 4 hours. This can be helpful if you've mistakenly left the SPD-SX's ...
Missing: js8 ‎' ‎Must include: ‎js8
The adaptor for the SPD-20 is not 12 V ac (Altern Current) the SPD-20 need only Altern current (12V AC) if the adaptor is 12 v cc, the internal circuits can not made +5v , 0, -5v for simetrical operactional supply. And Spd 20 show "Analog test err" and "batery low"
Permanently erasing the currently selected wave. 1. "[>] to delete." is indicated. Press [>]. If you hold down [SHIFT] and press [ALL SOUND OFF] in wave mode, you can jump to this screen. 2. A "delete, sure?" indication appears. Press [ENTER] to execute the deletion, or press [ "now processing.." is displayed. After execution, a "complete!" indication appears and the SPD- S returns to the wave mode.
Source: page 51 of the user manual pdf download: http://www.roland.com/products/en/_support/om.cfm?PRODUCT=SPD-S
Example: Enter the following x variables, and determine the sample and population standard deviations. x = {1,2,3}
Press
[DATA] and begin to enter the data as indicated into the L1, L2 or L3
lists. To input a data point, type the value and press [ENTER]. Press
the down arrow key to move on to the next data point.
Press [2nd], [STAT], and then choose 1-VAR.
For
the "DATA" option, choose the listname the data is stored in (L1, L2 or
L3). For the "FRQ" option, choose "ONE" since this data does not
include a frequency list.
Arrow down to "CALC" and press [ENTER].
Answers should be as follows: 3:Sx (Sample Standard Deviation) = 1 4:sx (Population Standard Deviation) = 0.816497
if you have the samples in .WAV then you will have to IMPORT them, because SPD-S can only play .SPD files (import will convert from WAV to SPD).If you have produced your samples with your SPD-S (via mic or line-in or PhraseMaker) then they are already in .SPD-format and can be assigned without importing. In this case you just have to assign a sample to a pad, by pressing CARD ("card"=lit) you can assign samples from your CF-card to a pad.
The card I have always been using is now also suddenly giving this
message. I found an old SanDisk 16MB and a 1GB SanDisk that works
perfectly in my Boss 864 and they also give the same message. Trying to
go into formatting brings the message "no card!"
