Televison & Video Logo
Question about Hyundai Electronics Televison & Video
I need service mode procedure for hyundai HYJ21SF1. pls help me. thank you.
Anonymous
By replacing the memory . thanks anyway.
Posted on Jun 11, 2009
How to remove factory sign in hyundai TV
The set is now on Service Mode option. You have to reset it to Normal. That is, you have to EXIT this mode. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Hyundai lcd tv HY2240FHF DOUBLE IMAGE PROBLEM.. Solution please?tell me remte factory mode?
It seems to be the fault with its main digital board. [Vertical synchronization problem]. Anyway, try a factory reset.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
How can I open service mode bye remote control?
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
I need onida tv 21 KYR4 model service code. Pls help me
How to opeo the service menu of skyworth lcd?pls
Hyundai tv service mode
2helpful
Factory mode for telefunken ttv 215C
Press and hold Volume - button on the TV panel, and Program + button on the remote control simultaneously. This must make it it service mode option. For some models, the procedure might differ. For more details http://electronicshelponline.blogspot.com/ check this link, and pull up older posts there. Service mode entry procedure, and adjustment, to many brand TVs are given in detail.
How do i install a 2 pulley water pump for a 1996 Hyundai Accent? I need a diagram or service manual. Thank you
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop & owner manuals, service bulletins, campaigns, illustrations and procedures, etc
2answers
My beko tv has a system setting on BG. I need to change it to L but it won't change. How do I change the system setting?
I need the same solution. My own system is setted up to 'I' and I want to change it to 'BG' but it doesn't work.
Hyundai Tucson 2.0L Year 2006
Get the mechanic to check the front CV boots for tears and get them to check the front CV joints. Explain the problem to the service manager. They should know how to properly check them. The shafts usually come as a rebuilt assembly with new joints on both ends, and are relatively easy to replace.
Top Hyundai Electronics Televison & Video Experts
Marvin
Marvin
Are you a Hyundai Electronics Televison and Video Expert? Answer questions, earn points and help others
