Projectors stops suddenly after start time depends: 2-5 minutes. Earlier the power supply unit was damaged. It was replaced but the situation repeats. In case of overheat (I guess) fan should continue to work but in my case it stops immediately with no any noise afterward.
2-5 minutes , it will not overheat
the power supply is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
SOURCE: Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
SOURCE: DV10 Color Wheel Replacement
Hello, the information is as follows:
Part no: 70.18r26g01
Cost: 129.00 + shipping
Model :Optoma DV-10
Contact no: (408) 383-3710
You may also contact the "out of warranty" repair department at 888.942.2929.
Glad to help.
SOURCE: Optoma DV10 projetor suddenly started made popping sound
hi,
Please Check and service the fans and the Air filters. then check again. In case the noise still comes then service the fans or replace accordingly. By complete service of projector, this will work.
Rave services
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
SOURCE: optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
