All plugged in and won't turn on, is this issue with XBox One or power brick that connects to outlet
I suggest plugging it into a different outlet. If it works then, then the outlet may be busted. Otherwise, if the light on the power supply (the brick) doesn't turn on when you plug it in, or the fan doesn't turn on, it may be the power supply. If the light does turn on, then it's probably your Xbox One, of which I suggest you take it to your local repair store (such as Best Buy) to get it checked out.
SOURCE: can you use a xbox 360 european power brick (220v) on a USA xbox 360 in europe
You must see the data on the brick label. If it says the correct tension (tension = voltage), yes, you can. But be careful because the Xbox's have three tipes of tension. It depends on the motherboard. If the mother is a Falcon, the tension is 14.2 V, but if it is a new Jasper, the tension is 12.1 V.
SOURCE: No power!
Duke, take a look at the big 'powerbrick' that powers your xbox, on the front of it there will be a small LED, it should be red/orange if your xbox is turned off. If you see NO LED light then your powerbrick is no longer functioning.
If you DO see a LED, then its likley the Xbox is at fault.
Hope this helps!
SOURCE: My xbox won't turn on
hey guys i was freakin out because i had that same problem. i didnt want to pay an extra 1000$ just because the stupid repair guys wouldnt tell me the answer. So look inside your broken usb port, there should be like golden prongs in there. if they are bent, straighten them and you can turn your xbox back on. Now this might not be the case with you, but that is how i just solved my problem. if you have any questions ill try to keep posted and see if i can help further. also you can get me at my gamertag for xbox live. its volcomxskater37
