Arctic Cat 2004 500 4x4 Automatic TRV Logo
A
Anonymous Posted on Feb 19, 2014
Jumped solenoid now no power
The solenoid was rusted so I connected the to wires straight together and jumped off with battery charger now I have no lights that come on
rich2481
Level 2:
Sergeant:
  • Expert 291 Answers
  • Posted on Jan 27, 2015
rich2481
Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
105882
Points
834
Most coils have a fuse in place on top of them, sounds like you blew it when you jumped it.
Rogerr
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Arctic Cat Expert 81 Answers
  • Posted on Jan 25, 2015
Rogerr
Arctic Cat Expert
Level 2:
New Friend:
Cheetah:
Answers
81
Questions
Helped
67064
Points
318
Sounds like you blew the fuse under the seat
here are the service manuals for all Arctic cat ATVs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
  • Rogerr Jan 25, 2015
    blown main fuse under the seat
1 Related Answer
scobby1234
scott saner
  • 14 Answers
  • Posted on Feb 19, 2014
SOURCE: jumped solenoid now no power
see if there is a fused link.if ther is it could be blown.hope this helps.joe
1helpful
2answers
2012 grizzly 2wd won’t start unless I jump the solenoid switch I’ve replaced the solenoid switch and the ignition assemble still won’t start without jumping what else could it be?
Did you check the starter button. Look to see if it has power then check the wire going to the solenoid and see if it is sending power.
Aug 20, 2018 • ATVs
2012 yamaha grizzly 700 new battery in just clicking noise showing error1
Just a couple wild guesses from 40+ years of experience...
1. the solenoid is bad.
2. the connections are not clean.
Make sure the ground wire from the battery is clean and tight to the frame.
Try jumping the two major solenoid connections with a HEAVY wire or (what most people use ( a screwdriver) and see if it starts...
If the engine turns over when you jump the connections, it means the solenoid is bad. If it does not you probably have bad connections at the battery + or - side.
May 30, 2017 • ATVs
Kymco uxv 500 wont start No matter what I do but it turns over with jump cables hooked up
Same problem with my mxu 500. Charged battery. Nope. Checked all connections in starting system. Nope. Swapped out solenoid relay. Fixed mine. Was cheap online- less than $20. Mine would start with jumper cables or batt charger on 80amp boost. Good luck!
1helpful
Nothing when turn key. Bought new battery and fully charged, installed, still nothing.
The "ticking" you hear is probably the solenoid trying to "connect"
The solenoid is the round thing that is the first thing the large red cable from the battery runs to. There are more wires connected to the solenoid..the TWO big ones carry the power from the battery and then jump it to the BIG cable that goes directly to the starter. You can CAREFULLY "jump" the two big connectors ON the solenoid with a screwdriver ( CAREFUL - SPARKS WILL FLY!). If the motor turns over you have a bad solenoid. Key does not have to be on, you just want the motor to turn over. NO open fuel sources!! SPARKS WILL FLY WHEN YOU JUMP.
Try this and repost, let me know.
My stator is not charging my atv battery, and my speedometer also does not work.
check to see if voltage is coming off the stator while running, AC volatage, from all 3 wires. if thats good you prob need a regulator/rectifier.
Feb 23, 2016 • ATVs
Power comes on but engine does not turn over or try to start?
If you get a clicking sound, then it is either your starter solenoid or the battery is low. If you simply get nothing, then it is wiring. Use jumper cables and and jump from an external battery. Go "-" to frame and "+" to the battery side of the solenoid. Push the starter button. It should click and send power to the starter. If it doesn't click then the problem lies with the wiring between the solenoid and starter button, or the solenoid itself. If the solenoid did click but the motor didn't turn over, put your "+" jumper cable directly on the starter motor's external contact. If the motor turns over, your problem is your solenoid. If the starter motor refuses to turn over, then your problem is the starter motor.
Troubleshooting arctic cat atv 650 twin, fuses are good but i can not even jump start, battery is fully charged, accessory switch, lights have no power. it ran perfect 2 days ago , I have read the manual,...
I think you have a dirty connection somewhere between the battery and the starter solenoid. Or... between the battery and the frame ground. Or - possibly - one of your battery cables is destroyed.
Don't keep trying to charge it or jump-start it if the battery is fully charged - you're wasting time doing that. Track down the battery cables and find the problem. Use a test light or a meter to follow the wiring - when you find where the voltage stops, you've found the problem.
Jul 26, 2014 • ATVs
Atv repairs
Hi Lee,
The starter requires substantially more current (amps) than the little wires and contacts that make up the start button and starter circuit. These small wires power a solenoid (an electro-magnetic switch) when the start button is pressed; which in turn closes a much larger contact that connects the larger battery wires to the starter motor.
You may have a blown fuse or fusible link, bad starter switch button, bad solenoid, broken wire(s) between the starter button and solenoid, poor connections at any of the terminals on these devices or a bad starter motor. Check the these circuits with a volt meter capable of testing 12 VDC or using a test lamp. Start with the one probe of the meter or lamp connected to a good ground or (-) post of the battery. The other probe should see 12 V (+) power on ONE of the starter button wires and on BOTH when the button is pressed. If not, work your way back to a bad connection or cut wire. Next, locate the solenoid. There should be two heavy cables and one or two smaller wires entering. The smaller wire is from the start button. Power 12V + should be on it when the button is pressed. If there are two smaller wires, one is probably ground or (-). If no power, check the wire for damage, etc. by following the wire back to the starter button. Once you have 12 V + starter circuit working into the solenoid, go to the next step.
Next, check the two heavy cables on the solenoid. One should have 12 V + power on it all the time and the other should have power only when the starter button is pressed. If you do not have power on one of the cables all the time, there is a bad connection,etc. between the solenoid and the + battery post. Check fuses, connections, etc. and make repairs. With power on one cable, press the start button A working 12 V starter circuit is required for this to work. If no power on the other heavy cable, the solenoid should probably be replaced. If you do have power out, it it still won't crank - check the cable between the starter and solenoid. Repair or replace as needed. If cable is good, the problem is likely to be the starter itself.
Apr 01, 2014 • ATVs
3helpful
3answers
When I push the starter button the solenoid clicks,starter does nothing.if I cross the 2 threaded bolts that extend out from the solenoid the starter engages? I just replaced the solenoid and at first it...
Just because it's new, doesn't mean it works.
This is why cars get recalled.
The iron-clan test of a non-working solenoid is to cross the relay terminals. If you do and it starts.. it's bad.
Take it back. you purchased a dud. It happens.
Top Arctic Cat ATVs Experts
Jonathan Buck
Jonathan Buck
vince
john h
Are you an Arctic Cat ATV Expert? Answer questions, earn points and help others
