Question about MDT Harvey Hydroclave SC8
Harvey Autoclave Hydroclave Mc8 "reservoir low message"
Bought unit and cant get to start because reservoir low message comes up
masud
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 582 Answers
Also clean out your chamber and pay attention to the sensors there...
Posted on Apr 10, 2017
Stan Skaggs
    Novelist:
  • 242 Answers
Need to clean your screens and filters.. also clean out your chamber and pay attention to the sensors there...
Posted on Mar 31, 2017
My early wRning light for low radiator fluid comes on at the start turn on my ignition, but it goes away shortly after. I bought 50/50 and filled the coolant reservoir to the full line. But the light still...
The CHECK COOLANT indicator illuminates when the coolant level is low in the coolant recovery reservoir. The low coolant level switch is probably in or on the coolant reservoir !
3answers
My machine is acting up its not starting. when i push to start is shuts down
I read through the user manual on this machine and it was of no help with this problem. What I can say is that some electronic devices will shut off immediately when turned on if there is a severe electrical problem in the device. Do the basics. Unplug everything, clean and reconnect all items. Check all parts that are opened and closed manually. Visually inspect these areas for damage or wear. Make sure water/steam is not getting into the electronic areas of the machine.
2answers
WHY IS MY EZ 10 GIVING A LOW HEAT CODE
Message is displayed and sterilization does not start if the autoclave has not reached sterilization temp. after heating for 50 mins. while in wrapped or unwrapped programs (80 mins in the Glassware program).
1) Clogged air jet, clean air jet.
2) no pwer to the heating elements.
3) Low line voltage delaying heat up. Not enough power to supply unit.
2answers
I need a manual for device
here is the operator manual for the MC8 hydroclave:
file:///C:/Users/212035112/Desktop/harvey_hydroclv_mc__8_10_user_man.pdf
2answers
Lack of water
Is it filled with water? If yes, then the liquid level sensor has failed in the unit. This will happen normally, but does happen frequently if you have growth in the water reservoir. Call for service. Follow instruction in the manual about flushing the reservoir.
Is my machine connected for 220 v ac can you provide a circuit diagram
you need to look at the end of the operator manual.. look here on the last few pages to see exactly what on the boards needs to be checked for 220V:
Startup
dear sir.
"checking disc comes up" this message is hard disk message and it's showing becoust missplase of harddisk thru yr laptop scoket if u know bout laptops u need to plug off then reconnect yr laptop harddisk otherwise contact system wonder near u.. it's help u.
I cant get it to turn on
Hi lillady909,
I'm Harvey the Master Plumber.
Your problem is: you cant get the lights or fan to turn on anymore is there a reset switch
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
MDT Harvey Hydroclave SC8 Logo
Top MDT Medical Experts
Don A
Don A
ADMIN Canada
ADMIN Canada
Are you a MDT Medical Expert? Answer questions, earn points and help others
