Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
A
Anonymous Posted on Feb 19, 2014
Cls1110 hold mon - Motorola CLS 1110 (1 Channel) 2-Way Radio
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Jan 08, 2015
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796347
Points
4248
Here's a link to the user guide http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CDQQFjAB&url=http%3A%2F%2Fwww.axcesstechnologysource.com%2Fmanuals%2Fcls_series_userguide.pdf&ei=1K6uVN3bIYikNsykg6AK&usg=AFQjCNHicPhdIfAnW0RvYf03G6KeqBqkBA&sig2=prqdNr24Qi09zfv9PolaTg&bvm=bv.83134100,d.eXY
How do I get my Motorola CLS1110 to talk to my Baofeng BF8883?
Justin
How can get my Motorola CLS1110 to talk to my Baofeng BF 888s
Mark
Motorola Mobility Support
Tip broke off 2 prong headpiece in accessory jack
Bridgette
You may get info by contacting Motorola Solutions
portal motorolasolutions com
Mark
How do i configure to code 1
Here is a link to the user guide. Programming begins on page 26.
http://www.weatherconnection.com/manuals/CLS1110.pdf
Best regards.
Where to purchase CLS1110 radio in Rochester, NY
The CLS1110 radio is available through businesses whose primary focus is not two-way radios. You might check Costco, Cabelas, Grainger, etc.
Also, the sister radio Motorola VL50 is nearly idential and is available at your local Motorola dealer.
Best regards.
How do i put my new cls1110 on prog 1 frequency 4
The CLS1110 is a one channel radio. However the one channel can be changed to another frequency and/or PL code. With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Best regards.
Is it possible to create a channel on a two way radio?
You have posted under the CLS1110 heading. If this is the radio you have here are the programming instructions: With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming2.gif mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
The CLS1110 has 56 built-in frequencies to choose from. You cannot program in a "custom" frequency. Only choose from the list.
I am trying to change the channel on my radio, how do I do that?
4helpful
My cls 1110 walkie is stuck on channel 1, how can i change it?
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
