Question about Connex 3300 240-Channels Base CB Radio
Power problems power stays on cant transmit or recieve
Anonymous
The power switch is fused shut you need to replace it and also the 5v logic supply regulator has failed perhaps this prob means there is no supply too the PLL and logic
this can all be caused by poor quality cheep power switched employed in every cb ive ever serviced rubbish and cruddy so check for all voltages and when and where you need them work from this
then youll quickly find the issue
Posted on Nov 23, 2014
Ranger superstar 33 no recieve
If you're still getting loud squelch noise but do not receive on any channel, you must check the RF from the antenna to the audio stage(not included). There must be more than just one RF stage in this radio. Let me know what you find.
May 08, 2013 | Radio Communications
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
I have syma s032g flown 6 or 7 times no crashes but it cuts power randomly and not at full power are the moters getting hot and dropping power if so do they make heat sinks for this bird
Having the same problem, something with the reciever or transmiter. Flown about the same 10 times, this just started 2 days ago and had it a month or so. The s032g are not UBS charged. I put new rechagable batties in the controller, nothing, took it apart nothing, unraveled the reciever wire a little (3") and got it going then this morning same problem. I am going to open it up and inspect the reciever to see it the wire came loss. I think it is the transmiter, it seems to happen when lowering the throtle, yellow lite on heli blinks and comes back after drop throttle to 0.
Oct 22, 2011 | SYMA Toys industrial Syma S032 Ready to...
I can recieve but i cant transmit have new antenna and new mic
Check that your mic gain or dynamike knob is turn clockwise if it is full counter clockwise you will have no modulation with your tx power.
I would like to help but one sentence describing your problem can lead to a vague solution.
Be aware that not all 4 pin mikes are wired the same.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Aug 28, 2011 | Cobra 29 LTD CB Radio
Radio stays transmiting after mic released
What happens if you "key up" and "let off" and the transmitter "hangs", you remove the microphone plug from the Cobra ?
Will it still be transmitting or will it stop ?
If it stops, the problem is in the microphone with a "hanging" switch which you can easily clean or replace.
Iif it keeps transmitting while the mike is disconnected, there is a problem with the Rx/Tx switching circuit. This needs further investigation by use of a circuit diagram.
Feb 13, 2009 | Cobra 29 LTD CB Radio
Will not stay on 11 meter turn it off comes back on 10&12 meter will not transmit am or ssb recieve ok. rci 2995dx.
Hello janetsue, If this radio has the blue or green screen LCD face then this is a default that is built into the radio. It depends on how the radio was "converted" when it was bought new.
It will not key up on 10 or 12 because of the default. A little more info supplied would be real helpful,,,, Let me know, Mechanic
Nov 01, 2008 | Ranger RCI-2995DX Base Scanner
Hands free
You do not mention what type of radio you are using. However, it is possible
1) you are plugging in the audio device with the radio turned on. If so, the result will be as you describe. Simply turn off the radio and replug the device with the radio turned off. In most cases this will solve the problem. Or a simple press of the PTT while it is locked in transmit, will return the radio to Push-to-Talk mode.
2) You are using an audio device which is not designed for the radio. OR
3) Your radio is stuck in Transmit.
If all else fails, shut off the VOX capability of the radio.
Oct 21, 2008 | Motorola Walkie Talkie 2-Way Radio
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Connex 3300 240-Channels Base CB Radio Logo
Top Connex Radio Communications Experts
Tony Raia
Lawrence Oravetz
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
