Question about Mtd Products Yard Machines 158CC Tiller
Need parts and engine 4 an mtd-211-405-143 tiller,is it worth it?
Was this tiller ok as tillers go?
Posted by garyhall305 on
  • 1 more comment
  • garyhall305 Jun 11, 2009
    Hi, the answer to your e-mail...yes,the last 3 # of the model # is (143)...the s/n is (A29-1A3)...the whole model # is (211-406-143).I want to rebuild it...if i get the parts, i need an engine ( a small engine dealer wants to modify a 5hp briggs and stratton...HE SAY,s i can,t find a engine for it anymore,with (2 shafts). I really need some sound advice!!ty
  • panilling9
    panilling9 May 11, 2010
    if you would
    Send me the Mod# type# and code # of the engine
    Should be a set of numbers stamped in line right on top of the engine cover or sides?
    Thanks
  • panilling9
    the last three numbers of the mod# 143 is that correct?
    do you have the serial #?
Anonymous
    New Friend:
Depth guage for a 5HP 206cc 5026-/6b rotary tiller.
Posted on Dec 08, 2010
Need operators manual for MTD tiller 214-430-000
Go to MTD website to obtain manual or google manual by model number followed by the word mtd or tiller
May 11, 2014 | Mtd Products Yard Machines 158CC Tiller
I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
May 30, 2011 | Mtd Garden Tiller (Mtd)
Belt broke on my 12 inch mtd yard machine front tine tiller model 21a-250m000 how do i replace it. thank you for your help!
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Feb 27, 2011 | Mtd Products Yard Machines 158CC Tiller
Have a tecumseh ohh50 4 cycler engine on a garden
Check for condensation in the tank. Fill with FRESH gas, then if no luck, proceed ...
Main jet partially blocked. Undo bowl nut. Some models have the jet in the side of the nut - check and clean. If not, the jet is in the emusion tube of the carb - accessible throught the bowl nut orifice. Clean out & test.
Jul 23, 2010 | Mtd Garden
How can I find a parts manual/breakdown for an older Troy Bilt tiller? I beleive it was manufactured in 1987 possible model #870487 definite S/N 87 46 39. This tiller has the 8 HP Kohler engine. I am...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in horse for your model number and you should be able to find a parts break down for your tiller. If the serial number is 874639 it was made in 3/88 and will be a four speed PTO model.
I find a lot of parts on Ebay for these tillers, your can order parts through MTD but they will be a little pricey. MTD aquired Troy Bilt out of bankruptcy in 2001 and still carries parts for the tillers.
Frank
Jun 27, 2010 | Troy-Bilt Garden
I have a 1996 MTD front tine tiller that was left in someone's shed for about five years. I have emptied the fuel and oil from the tiller and want to rebuild or replace the carburetor and fuel line before...
See if you can find the model number on the engine and then go to the Briggs and Straton web site for the manual for the engine. The tiller manual will not have engine info in it. I hope this helps.
May 31, 2010 | Mtd Products Yard Machines 158CC Tiller
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
MANUAL FOR 1994 MTD TILLER
www.ereplacementparts.com/mtd-215412000-1985-tiller-parts-c-20039_20363_20380.htm
Jul 09, 2009 | Garden
Need the owners manual for TB-144 tiller
Go to troy bilt pony horse tiller pto manual owner cd. And you can locate the manual you are looking for.
May 19, 2009 | Garden
I have a 1996-1998 MTD yard machines,rear tine, dual wheel,chain drive,counterweight in front, walk behind tiller. It has the traction drve control on the left bar and the gear selection, side to side...
http://www.outdoordistributors.com/MTD/MTD_Main.html
click this link directly
Customer Service Phone Center Hours
are from 8:00 To 4:00 Mon. thru Fri.
(Central Time)
Click Here To See "US"
If You Are Ready To Order,
And Need Assistance, Please Call:
Toll Free 1-877-70-PARTS
(Orders Only Please)
If You Are Not Ordering
But Need
Information Please Call:
1-205-669-2500
More Contact Information
Click Here
one more good link for ordering parts
http://www.milacalawn.com/parts.asp
Apr 06, 2009 | Mtd Products Yard Machines 158CC Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
389 people viewed this question
Top Mtd Garden Experts
Dennis Key
Dennis Key
dannydoesita
Marvin
Marvin
Are you a Mtd Garden Expert? Answer questions, earn points and help others
