HP Compaq nx9420 Notebook Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Complaining about hard disk not inserted
Am trying to reload my laptop with window xp and is complaining about hard disk not detected,there is hard disk in it and is well fixed,but still the same problem persists.
danoyachtcap
Level 3:
Top Expert:
  • HP Master 2,907 Answers
  • Posted on May 05, 2015
danoyachtcap
HP Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1274894
Points
52081
I usually press F12 or F2 or F8 or 9 during boot up until I find where to select the hard drive.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 08, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
618
Points
You need to log into your bois and change the device settings for the Hard Drive Sata Native Device to disabled for it to allow windows xp to install. I ran into this problem as well during my setup
Anonymous
Level 3:
  • HP Master 32,281 Answers
  • Posted on Jun 10, 2009
Anonymous
HP Master
Level 3:
Answers
32281
Questions
Helped
7907990
Points
102259
The problem is either the BIOS is not detecting the hard drive or the hard drive is faulty or the disk controller is faulty. Check the BIOS setting to see if it has detected the hard disk, and if there is a hard drive diags run it to test the hard drive. Try reseating the hard drive and if it doesn't work, remove the hard drive and connect it to an USB hard drive adapter. Plug this adapter into a working computer's USB port and if this computer detects this as an external hard drive and you can view and open the various folders and files, then the hard drive is OK. If you haven't any files or folders in the hard drive, then format the hard drive from this computer to test this hard drive. If the hard drive is OK then the fault is probably the disk controller. If the hard drive is faulty, then you need a new hard drive in your computer.
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Hello my laptop wont open,it brings numbers that ask me to insert a boot disc,i dont have any ,what shall i do to start to start my windows.
Hi "Wambuilyds"
It show no hard disk is detected in your laptop, please check your BIOS to know the Hard disk is detected, also try to re connect your hard disk.. if the problem exists buy new Hard disk and install windows again,, Thank you
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Acer Aspire 4315 when i formatted the it is shown hard disk drivers not detected quit or restated the system.
If you are formatting this model Acer usinf the Windows XP installation CD then Windows cannot detect the hard disk because this Acer uses a SATA hard disk and Windows XP cannot detect a SATA hard disk. The Windows XP installation CD does not include a SATA driver in this CD.
To format and install Windows XP on your Acer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
My dell 470 cant detect any hard disk while installing windows xp what should i do?
If the BIOS cannot detect the hard disk then most likely the hard disk has failed.
Try removing the hard disk and inserting it back into the computer, just in case it was not making proper connection.
If this did not fix the problem, then you need to replace the faulty hard disk.
I have problem to install window xp in my laptop, which already have window vista....my notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70477
Windows not detecting hard disk
I had the same issue with sony vaio, try to download superdisc and the burn it to a bootable cd. Boot the system from the superdisc and then try to erase the MBR and then try to install, it should work.
4answers
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Gowthaman
Check if the jumpers on the hard disks are in the right position.
2helpful
2answers
XP on HP Pavilion dv2000
yes
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/HP-Pavilion-dv2054ea-SATA-Driver-550.shtml
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
  1.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
