Question about Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv
Champion c42412-1 runs but no output
My champion generator will start & run ok but there is no output. I ran it for a year, it sat for 6 mo. then I started it, tried to run some tools off of it & there's no output.
1 Related Answer
KMusselmann
KMusselmann
  • 247 Answers
SOURCE: Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Posted on Mar 20, 2009
7500 champion generator used breakers were tripped they wouldnt reset but ran great good voltage for about 3 weeks now it still runs great but the voltage meter bounces on 0 wont power nothing
If it has sat, it may have lost it's rotor residual magnetism.
Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged.
If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Dec 26, 2014 | Electrical Supplies
Only runs with choke
There is an air leak in the seals somewhere between the carb and the intake manifold. You are getting too much air! ALL of those seals need to be changed, As the paper seals age they develop small cracks that kill the vacuum made by the engine to pull in the gas/air mixture!
Dec 23, 2012 | Champion International Champion Power...
Cant get my power ate 8750 to start. Ran fine last year. Have changed spark plug, aded fuel stabilizer, will starting ether help?
My son in law drained the carborator 3 times to get the old gas out. Also put in an additive to the gas. He figured our unit had sat too long and the gas was getting old. It is running fine now. Just need to figure out how to idle it down.
Oct 28, 2012 | Coleman Powermate 7,000 Watt 13 Hp...
Yamaha ef1000is was rained on, starts and runs after unplugging wire plug from generator, runs when replugged, but no electrical output
Sounds like the rectifier got fried. Moisture in these units is a dangerous thing. Even if you feel the unit sat long enough to dry ouit, it sometines will hold moisture in the electrical componants.
Jan 15, 2010 | Yamaha 1,000 Watt Portable Generator...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv Logo
74 people viewed this question
Top Champion International Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
