LG X-Note LM50 Notebook Logo
Zidane Selner Posted on Feb 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bootable not detected - LG X-Note LM50 Notebook
justwinwin
Level 3:
Master:
  • LG Master 788 Answers
  • Posted on Mar 01, 2014
justwinwin
LG Master
Level 3:
Master:
Answers
788
Questions
0
Helped
96199
Points
1542
What is your media? If it is not an original media, I prefer to use CD-R or DVD-R because some drives do not read DVD+RW well.
Bootable memory not detected
are u sure u made the bootable memory properly? what is the bootable actually??? windows or linux??? most of the time the bootable can be accessed by pressing 'F10' key there u can choose the media.
5helpful
2answers
A bootable device has not been detected in Intel 945GNT motherboard
solving of problem of a bootable device has not been detected. Please refer to the product guide at http://support.intel.com/support/motherboards/desktop/
I dropped my computer, now when i turn it on the screen is black and a text appears which says : For Atheros PCIE Ethernet Controller Check cable connection! PXE-MOF: Exiting Intel PXE ROM No bootable...
Hi, your laptop will try and boot an operating system in a given order denoted under your bios, usually it will look for a bootable cd or dvd first (which is why the light on your cd/dvd drive flashes when you switch on your laptop), it will then try and find an operating system on the hard drive and if all else fails will try and boot from a network connection. In this instance it looks like what it is telling you is that is has failed to detect bootable media in the cd/dvd rom drive (i.e. no windows disc), it has failed to detect a bootable hard drive and it has failed to detect a bootable network connection.
It sounds very likely that either your hard drive was damaged in the fall or the connection has become unstable so first off remove the lower covers from your laptop and remove and refit your hard drive, try to power it up and see what happens. Let us know how you go.
Hope this helps
John
1helpful
Won,t boot up
hard drive is faulty as it cannot be detected by the bios of your laptop. and/or your optical drive has no bootable cd in it. you may need to install a functioning hard drive with installed operating system for it to detect that the hard drive is bootable.
1helpful
Gateway gt5404 reads no bootable device pc seemed to siow down some then went black was after micro. soft update ? unpluged twice pulled batt. reconected it worked set clock back worked awhile went black...
Any hard disk that makes clicking or metallic noises is faulty, especially when POST error message no bootable devices detected.
To confirm go into the BIOS setting and see if the hard drive is detected, if it cannot detect the hard drive then it is definitely faulty.
Replace the hard drive and install Windows on the new hard drive to get the computer working again.
22helpful
4answers
A bootable device has not been detected.
Please refer to the product guide.
2answers
DVD not detect at bios. why
if you press enter or space when you have an item highlighted does it not give you the option to add the dvd / cd ?
On some bioses it is there its just that its been disabled as an extra boot device to speed things up so that its not always trying to read or find a cd to boot from so if you press the key it requests you to ( near the bottom of the screen when you are in the bootable devices section ) it will explain how to alter or add them. If you follow the instructions you should be able to add it as a bootable device
If its not detecting any discs in the drive whilst in the bios thats because you need to save the settings in the bios to boot from the cd / dvd and the disc ( cd or dvd ) has to be made bootable and then once the bootable disc is in the cd / dvd drive and you have saved the settings in the bios and restarted it should boot from the disc thats in there.
If you need to make a disc bootable you can either use nlite or you can get guides on how to make a disc bootable if you search google.
Your operating disc and a linux disc(s) are all bootable
2answers
Bios not detecting bootable harddisk
Repair windows xp using bootable windows xp cd..
Bootable CDs are not working with my new DVD writer
Try to update your BIOS first, then call me in the morning.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
