I have a standard sanyo tv i use for gaming. i have the tv on input video1 and i cannot get the video1 , 2 component, or 03 off the screen to see it in its entirety. any advice? the remote model i think is fxvr any advice would be great thanks
There is button on your remote labeled TV/AV . Press the button to get a blank screen with AV written on the screen. If your game device is connected at the back to this AV socket ( Yellow / Red / White ) you will see the game menu display. On some of the TV remotes it might not be written TV/AV but INPUT SOURCE or just a picture of a TV screen with an arrow pointing inwards ( that LOGO is the universal symbol for INPUT )
first have the video recorder connected to the tv correctly,either coax out, red.white,yellow out, componant out or hdmi.[ see on back of the unit & the tv which connection you used.input selector is also known as video/source/line in or aux, sometimes even game. if there no such button on your remote, scroll down from channel 2 and you should be in some aux input.have the dvd playing,then you should see the video when you get to the right input.
wg
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
The reason you're getting a blue screen is that you're not getting a signal. Newer TV's have this "blanking" feature to "kill" the snow in the absence of a signal. Check the connector at the end of the cable where it screws onto the set.
Stargazer
