Im trying to figure out were to hook up the reverse wire on my power acoustik to my 2007 mercury grandmarquis i dont know were to hook it up to the wire is pink coming from my unit were is the reverse wire on my mercury grandmarqius
SOURCE: i dont know were the ignition wire is im trying to
Ignition wire is any switched lead that is off when the key is off.
In a 1998 Sentra, the wire behind the radio that is a switched power lead is BLUE.
Double check with test light or voltmeter.
Thanks for using FixYa - a FixYa rating for answering your FREE question is appreciated!
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
SOURCE: POWER ACOUSTIK PADVD-330 DVD Player issues.
if your pioneer radio has the light blue ipbus/changer plug on the back of the radio, you can use this adapter and turn on the <aux> in the menu where you set the clock.
http://cgi.ebay.com/Pioneer-IP-BUS-Aux-In-Input-Adapter-CD-RB10-for-iPod-a3_W0QQitemZ400030920263QQcmdZViewItem
SOURCE: what color wire do i hook the pink wire to
Pink wire is generally the parking brake safety. If you dont want the dvd player to play video while in drive wire it to the ground on your parking brake sensor wire. If you do want it to play video while your driving, wire it directly back to the ground wire on your stereo.
SOURCE: Installed reverse camera to Eonon
i had the same problem with my talon today, all you need to do is get another wire , connect one end to the 12v(red)backup tail light wire and connect the other end to ur dvd player and put it one the wire that is to be connected to the 12v for the revarse camera the wire should be orange but urs might be a different color.
