Question about Element Electronics Televison & Video
I just bought an element TV and I am using a coax cable to hook it up to cable, I do not have a box or anything just straight from the wall. However, I am only able to get like 22 channels. All of my roommates are able to get all of our channels. I was told I needed to put a code in but I cannot figure out where to put the code. They have all the codes listed online I just need to know where to put the code in at.
Posted by Mary L Stryker on
zimcloud
    Scholar:
  • 135 Answers
You will need to use the TVs remote to put in the code
Posted on Jul 02, 2017
2 Related Answers
3764alan
Alan Spicer
  • 127 Answers
SOURCE: Philips flat tv. Can't get it to hook up to dish
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Posted on Jul 07, 2009
westytech
vidal chavez
  • 120 Answers
SOURCE: I initially used a code
Hello Nicolelc1234, I can help you set your TV up live, please send me an email to [email protected] so we can go ahead and set that up.
Posted on Jul 01, 2011
How do i hook up mono tv with eterxnal speakers with a dvr box
If the DVR has RCA-type connectors, yellow to yellow for picture, and white to white for sound. Tune tv to line input.
If the DVR supports outputting everything on coax, use a piece of coax cable, and tune tv to channel 3.
Your coax cable from wall has to go into DVR first, then out to tv.
Aug 26, 2014 | RCA F32650 32" TV
Viore LCD26V37HA Won't Work With Cable
where did you hooked up the cable box, how about the settings in the tv did you checked?.
Aug 15, 2012 | Viore Televison & Video
Can't turn off the closed captioning
I had the same problem. Okay, First get the TV remote. not a cable box remote. Next, switch the input to an Analog input. (TV or input one if you have the RC red, white and yellow hook up. or, just hook up the coax cable straight to the TV..
Now, use the TV remote to operate the closed caption. It will work like it should.\
Briefly, closed caption works on the TV with a straight hook up to the TV. It will not work with a cable box.
Good LUCk
Monty
Aug 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
To hook cable to tv
tke the coax cable coming out of your cable box and connect into the coax connector on
your tv.put the tv on channel 3 and change channels with the cable box.if you do not have a cable box run thcable from the wall into your
tv and auto-program the tv.
Jul 28, 2009 | Televison & Video
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Televison & Video Logo
49 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
