Question about Konica Minolta Bizhub C652 Color&b/w Copier/printer/scanner/fax Network,finisher
Bizhub C652 has horizontal lines.
Lines are about 1mm apart. Only in copy or scan mode. Prints are fine. Problem occurs through RADF or off glass, In mono, color and single color.
Posted by Bob Wright on
classic xerox point
Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or bink lines. This is a brand new c452.Scan to PC is ok, print its ok only copy. Lines are vertical.bizhub C652 has horizontal lines. - ea2265a7-6bf2-4ab0-abb0-94d103145c4c.jpeg
Posted on Sep 01, 2020
Pete Fotheringham
    Novelist:
  • Konica Minolta Expert
  • 175 Answers
Its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Posted on Feb 19, 2014
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the seco
Is it prints or copies or both? If it's copies, clean the document feeder glass - small strip. What make/model? Laser? If laser, check the fuser roller
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
I have an HP C5100 printer/copier/scanner. When we print to it the result is fine. However when we make a copy of something the copy prints out with random short horizontal lines. The location of the lines...
The problem will not be in the print head as you would have the problems when printing and copying . Do the lines appear when you are scanning. If so I would think that the problem could be in the optical unit. check that the unit is plugged in correctly. make sure that any covers above the glass on the optical unit are clean. I will check to see if a calibration can be done.
2helpful
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
4helpful
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
1helpful
2answers
My Pixma MP830 is printing horizontal lines of various width across the page when printing or when copying from a single sheet laid on the glass.
Hello sir; what you need is cleaning, you neeed to clean prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easy to clean ink cell.
HP PSC 1610 - multiple lines in scans and copies, prints OK
Try a sky scan (No paper on glass and lid up) watch the scanner to see if it is smooth or a somepoint jumpy. If not smooth, you will have to open it up and 1 of two things, dirty and needs lubracation, silicone grease is best vasoline will work. OR 2 the drive belt is loose because the spring tensioner is broken or the belt is dammaged. Good luck
Konica Minolta Bizhub C652 Color&b/w Copier/printer/scanner/fax Network,finisher Logo
Top Konica Minolta Office Equipment & Supplies Experts
George Mclaughlin
Ekse
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
