Question about JVC KD-G200 CD Player
JVC KD-R200 won't power up for more than 5 seconds
Just installed my brand new jvc kd-r200. Won't power up using the buttons on the head unit or remote. Will power up for few seconds if I press the DSP (display) button, showing the time. Or will power up for a few seconds if i press the eject button, while showing "eject" on the display. Otherwise , Nothing. Have tried the reset button a few times. Still nothing. Clock resets each time I reset so I it is indeed resetting Please help!!!
Thanks
Tony G.
Posted by tgrdracer on
Anonymous
    Problem Solver:
  • 8 Answers
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
Benjamin Redington
    New Friend:
  • 4 Answers
I had the same problem with a JVC KD-AHD69 after clearing trouble codes in my Jetta. I called Crutchfield tech support and was told the symptoms point to constant or ignition switched power sources (both must be on for the stereo to work). Since Jetta has CAN bus and no direct ignition switched power (requires an adapter), possibly the CAN bus module is not working properly. Recommended solution is pull the stereo out and check for power on yellow and red wires when the ignition is on. Check any inline fuses, and (in my case), with everything off, unplug the adapter module for 30 seconds. Then plug it back in and cycle the ignition 5 times about 1 second each. I hope this works...
Posted on Mar 18, 2012
How to set time on JVC KD-R200 car radio.
Try this.
Press and hold the SEL button. When the menu appears, if pressing left/right button doesn't select clock, try turn the volume to select and press right/left to set. Let me know it works.
Feb 09, 2015 | JVC KD-R200 Car CD/ MP3 Player
JVC kd-r210 flashes and won't power up?
Sub
You need to look through the JVC KD-R210 manual.
A JVC Dealer / Installer may have seen a similar problem & suggest remedy.
Jul 14, 2014 | JVC Kd-r210 Car CD/ MP3 Player
Jvc kd avx33 faceplate power light comes on. i hit power button it lights up blue then nothing it beeps then i hit the power button though.
Problem with KD-R200 or KD-AVX33?
What does it mean by "it lights up blue then nothing?" Does it takes CD in?
Oct 26, 2013 | JVC KD-R200 Car CD/ MP3 Player
How do i set the time on my car stereo it's a jvc kd-r200
Hold the SEL button to bring up the PSM menu, use up/down to select CLOCK H for hour or CLOCK M for minute, turn the knob to adjust, and press SEL to set.
Full details are on page 3 of the manual.
Mar 10, 2012 | JVC KD-R200 Car CD/ MP3 Player
How do i set the clock on my jvc kd-g420 ?
Setting the clock is usually done on JVC head units by pressing and hold both the EQ button and the SEL button, keep them pressed for about 5 seconds and a menu of options should show and you can scroll through the menu with the forward and back buttons.
If the above button combination does not work, you can try pressing and holding the SEL and DSP buttons and holding for about 5 seconds.
I’m happy to assist further over the phone at https://www.6ya.com/expert/cody_a1e78820c0d52932
Mar 01, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do you set the clock on a JVC KD-R200 car stereo?
Press and hold SEL button until the menu appears
Using the scan (FWD/REV) button, select Clock H
Using the volume knob, set the value
Using the scan (FWD/REV) button, select Clock M
Press SEL to save and return.
Jan 22, 2010 | JVC KD-R200 Car CD/ MP3 Player
Wont turn on
  1. go over all the wiring and make sure nothing came loose.
  2. find the reset button usually behind the face. reset the radio.
  3. make sure the face plate is completely on the head unit.
Dec 23, 2009 | JVC KD-R200 Car CD/ MP3 Player
How to set time on a jvc kd r200 cd/mp3
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Nov 03, 2009 | JVC KD-R200 Car CD/ MP3 Player
Need to set clock on jvc kd-r200
Press and hold SEL to display the menu
Using the volume knob, select the valud
Nov 01, 2009 | JVC KD-R200 Car CD/ MP3 Player
JVC KD-G200 CD Player Logo
1,440 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
