Question about HTC G1
When I turn on my g1 it stops at the android screen and keeps cycling and will not boot up. What do I do?
Posted by vigallon on
Anonymous
  • 4 Answers
Easy i just figured it out with my g1 and g2 both with the same problem. The solution is this: Try taking out the battery put it back in. press and hold the power+home butto. a screen will show then press the power and home button agian. It will then give you a choise to whip out ur memery to factory settings and it should work after.
Posted on Jul 31, 2009
  • Anonymous Jul 31, 2009
    das for the g2. Now the g1 is similar but then u would open the key and press back return and home
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 | HTC G1
Whenever i turn on my htc g1 it starts up and shows the sing G1. Then when it goes to the ANDROID loading section it takes 1-2 minutes and then stops?? why
Take out your SD card and try booting it up. If that does not work then power off your phone and hold the end and call button at the same time for about 15-20 sec, press Alt-W at the same time, to do a factory restore (this will delete all your data). Then restart your phone and it should work.
Sep 01, 2010 | HTC G1
My g1 tmobile phone keeps turning off on me? what can i do
If it keeps rebooting itself at the G1 and Android screen, you might want to factory reset the phone and clear all the data as there may be a virus. To do this, when turning on the phone, hold the home button and the power button even while the G1 screen comes up. Keep holding these until an image with a triangle comes up. You will then wait 5-10 seconds, and press the home and power button again together. This will bring up the OS screen, and provide you 4 options. One of these options is to wipe and restore to factory. Do this and your phone should work fine after you reboot again.
Apr 10, 2010 | HTC G1
Phone not loading g1
You may need to wipe the factory setting. To do so, Turn Off the cellphone, now keep on holding the Home button and turn on the cellphone. It go to the recovery console, now select WIPE or press the short keys mentioned over there and restart cellphone.
Note: You will not loose any data but you may need to resign to google and also may need to install some application.
Thanks and regards,
Anil.B.R
Apr 09, 2010 | Google Android
I dropped my t-mobile G1 today and it came on but it keeps rebooting. It will viratte then go to the black g1 screen then to the black android screen. It works for a little bit but then justs shuts off...
i dont think theres a virus my phone does that all the time just take the battery out and the sim card and put them back in and turn the phone on
Mar 23, 2010 | HTC G1
When i turn on phone after android logo appears screen turns blank and phone will not turn off you have to take battery out
Try getting into recovery mode. Hold down home and press power. Keep holding home down while the phone boots. Can you get into recovery mode? You can just pull the battery after testing this.
You can also try holding "menu" while booting. This should put you in "safe" mode. If this works, then use the settings menu to do a factory reset and reboot.
Feb 26, 2010 | HTC G1 Smartphone
My android is stuck on the G1 screen did a soft and hard reset still stuck on G1 screen. Any suggestions?
can you get into recovery mode? (hold down home while booting) or into the bootloader? (hold down camera while booting). If you upgraded the radio without upgrading the spl, then you can get to the state where no other boot works. There is no documented method to get out of this. They call it "bricking" your phone. Holding down the "ball" causes a slightly different boot that might allow recovery, but nobody appears to know how to do this yet. It may be that some of the extra pins in the 11 pin HTC USB are useful in this mode, but again, nobody knows howto yet.
Dec 26, 2009 | Google Android
HTC G1 Logo
292 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
