this is a easy part to replace,, if the tumbler still works and you can
start the car ,,, put the key in the tumbler and start the car up ,,
this is the position ware the tumbler is ready to come out ,,,, if you
look on the bottom steering column bezel there is an access hole in the
plastic panel ,, use a pick , or something like a pick to insert it into
the hole and push up ,, this will release the lock tumbler pin and you
can wiggle the hole key and tumbler out of the steering column ,,,,,see
below
then put the new tumbler in the same position and depress its pin ,,
slide it in the hole and shut the car off ,, this will force the pin out
and the tumbler is now in place ..
Good luck.
