Question about LG 22" FLATRON LCD Monitor
I have pink color horizontal lines on my LG LCD monitor screen,How do i solve it?
Posted by manikanda59641 on
AYYU
    Guru:
  • 377 Answers
You can fix you have to follow this instruction
1-Reset the TV by unplugging its power cord for 30 seconds and plugging it back in. This is an essential troubleshooting tool as a simple reset often will resolve the great majority of technical issues experienced by any kind of TV. Power the TV on after plugging it back in and check the picture for any improvement.
2-Unscrew the coaxial cable that attaches your wall cable outlet to either the coaxial cable input on the plasma TV or to any digital cable converters you may use at home. Check the copper needle in the middle of the cable for any bending or damage and screw the cable back on the coaxial input. Again, check the picture for any improvements.
3-Secure the audio/video connection cables that attach the source device you are trying to watch to the plasma TV. This is a particularly important step if you use component cables. Component cables separate a video signal into different colors, so a damaged or loose component cable can lead to noticeable discoloration on the screen. Once the cables are secure, both in the source device and the plasma TV, check the picture again to see if this may have resolved the issue.
4-Scan your channel lineup and check the other TVs in your home to determine the scope of the problem. If you see the discoloration only on one or a few channels, and the same channels are discolored on the other TVs in your home, you may be part of a cable service outage and you will need to report the issue to your cable provider. If all the channels on the one TV have the same discoloration, and the other TVs in the home look normal, the plasma TV likely will need to be serviced for a problem with its picture components.
hope that it helped
Posted on Feb 19, 2014
5 Related Answers
viziks
Samir Shah
  • 220 Answers
SOURCE: LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Samir
Posted on Dec 10, 2008
JESTERBOY38
MATT GIBSON
  • 5 Answers
SOURCE: LG Flatron 795FT Plus - horizontal lines on screen
YOU NEED TO CHECK TO SEE IF THE CAPASITORS ON THE POWER SUPPLY AND MAKE SURE THERE NNOT BULGED OUT OF LEAKING IF THEY ARE THE NEED TO BE REPLACED
YOU SHOULD BE ABLE TO FIND EVERYTHING YOU NEED AT RADIO SHACK FOR LESS THEN 20 BUCKS
Posted on Feb 05, 2009
anjana03
Roshan Rijal
  • 361 Answers
SOURCE: LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Posted on Jun 15, 2009
Anonymous
SOURCE: Color patching
And move it away from the magnet or speaker :) Speakers are cookie monsters for screens.
Posted on Aug 01, 2009
Sphynkter
Sphynkter
  • 221 Answers
SOURCE: blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Posted on Mar 03, 2010
This is Jon Baker from Sacramento, CA have a TV LG 50PZ55-UA have a lot of PICs that show model of the TV /boards - can you help on which board maybe the problem?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 21, 2016 | LG Televison & Video
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
What is the problem if my LG w1934s-BN LCD monitor when the color of the screen is pink ?
The reason for that is because the main board inside of the monitor is bad and since there are no parts for that monitor available you would need to replace the monitor. The main board controls the output of colors onto the lcd.
Sep 30, 2010 | LG W1934S-BN 19" Monitor
I'm using an Acer laptop Aspire 4920. Yesterday a horizontal line appeared at the bottom of my screen. I line moves and changes color . The colors are pink and green. TQ. jane.
The line may indicate 2 things, your video card is corrupted or damaged, or or lcd monitor is itself damaged. Proceed to your local service center/supplier.
Goodluck
Tedmac
Sep 18, 2010 | Acer Aspire One PC Notebook
Pink color horizontal lines comes on and off
That issue is with one or more of the board that drive the plasma screen. If you have a warranty, you will want to call LG for a free repair.
Sorry, but to trouble shoot that issue would require some TV tools and knowledge of electronics. There are several boards involved with processing the picture image to the plasma screen.
I hope this information has helped you.
Good Luck.
May 24, 2010 | LG 50PS60 50 in. Plasma HDTV
How to remove pink line on my lenovo
Is it a pink line down the screen vertical or horizontal. Most likely it is a screen problem and you will need to replace the screen. Check the repair directory on FixYa.com for a reputable laptop service to take care of the problem if you are not comfortable replacing the screen yourself.
Aug 02, 2009 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Screen just flashes horizontal pink & blue horizontal lines when you turn it on
It sounds as though you may have a faulty lcd. Replace lcd(screen) and see if it solves the problem
Sep 25, 2007 | Vivitar ViviCam 5385 Digital Camera
LG 22" FLATRON LCD Monitor Logo
129 people viewed this question
Top LG Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
