Question about Panasonic PT-47WX53 47" Rear Projection HDTV
42 " Panasonic
I can not get the convergence set right the red seams to be bend and when I try and adjust the screan position the vert. line just bends either at the top when ajusting left or bottom when adjusting left
Posted by jetmech55 on
ladywinn
  • Panasonic Master
  • 5,138 Answers
Have you ck 2.2 ohm resistors, try looking near ics ck all low ohm resistors.this can cause your problem.
Posted on Dec 21, 2007
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
Apr 22, 2012 | Mitsubishi WT-42311 42" Rear Projection...
Picture is distorted. Red band from top. Is this a repair I can do myself?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 28, 2010 | Samsung HCN4226W 42" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
No Convergence, Picture is bowed and distorted
  • Screen looks 3D
Jan 02, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Toshiba 41h81 green convergence problem
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
  • Screen looks 3D
Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
Fuzzy picture
never adjust the tubes themselves( No-NO) these are affixed to the chasis in one position and not to be moved. no adjustments should ever be attempted to anything directly attached to the tubes. this will throw off centering, soft-focus, & convergence alignments. it can be corrected but a huge burr on the bottom of the foot! what you have are faulty convergence ic's and maybe sme low-ohm resistors that are bad. repair in-home should not exceed 350.00. parts and labor. mch
Mar 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba v43j22p 42" red shadows and lines over screen
6b5ee7e.png You may have a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 02, 2009 | Toshiba 57H81 57" Rear Projection...
Convergence adjusting
you need to replace the 2 stk-110's mounted to the heat sink
i had the same problem
and works pretty good now
Dec 26, 2007 | Toshiba 42H81 42" Rear Projection...
Convergence problem w/ red horizontal only-WS-65807
Do not try to adjust anything yet!! Adjustments do not get out of alighnment all of a suddenly. The convergence adjustments are there to do minor aging alighnments. I would first check for bad solder connections on the convergence IC's first.
Sep 08, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
