Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
Turn off program timer on panasonic tv
Cannot turn it off
My tv keeps turns on for a quick second then turns back off
Please test the TV with all connected cables removed and the power cord connected directly into a different wall outlet.
If the problem continues then use the below link. www.panasonic.com/repair Welcome to Panasonic Online Repair
Tv wont turn on
On a lot of the Panasonic units that is normal--idiot light that means nothing at all.
Some people actually cover it with tape so do not have to look at it.
T.v wont turn on
The light means nothing---if TV will not turn on or comes on briefly and shuts down--could be a jammed or not working mechanism in the VCR or the TV may have a power supply problem.
10helpful
2answers
How to reset lamp timer on panasonic pt-52lcx16
Turn On tv, press and hold Volume Down button on TV Front and Play/Split button on Remote at same time for six seconds to reset lamp timer.
TV screen will show lamp timer reset display upon successful process.
2helpful
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
1helpful
I have a Panasonic VCR PV-V4202-A. I want to
You need to go into the menu and look for timer recording,then set in the channel,dateand time the program starts,then press the timer button.It will not start recording until it gets to the time the program starts.
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
4helpful
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Open Questions:
See all Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Questions
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
