From http://home.howstuffworks.com/how-to-repair-an-oven3.htm Servicing Fuses If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. Electric Oven Troubleshooting Guide There are a myriad of problems that can cause your electric range or oven to malfunction. Click here for instructions on how to deal with specific issues. If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused. If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
Most if not all ovens do not have fuses
perhaps if you gave a model number
