The inlet valve is probably stuck. It is a flat poppet type, so you need to free it up. A Graco dealer should be able to supply a special small plastic bottle with a special top filled with their Pump Armour to do this job. Otherwise you can unscrew the inlet valve from the cup side to clean it out, but be careful not to lose the small spring. You should always flush Pump Armour through the ProCoat after use otherwise the passageways corrode
