Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
Whirlpool refrigerator model GI6FARXXB06 leaks water every couple of days.
Water seems to come out of the right hand corner of the freezer door. Inside the freezer under the drawer is nothing but ice from where its been leaking in there. Just don't know where it's coming from. Been doing thus for a couple months now.
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: defroster leaks
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
Anonymous
SOURCE: water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
arikrom
911 SERVICE TODAY
  • 528 Answers
SOURCE: Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Posted on Jan 02, 2010
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: My whirlpool refrigerator 21TFA is leaking water
The drain is clogged. Remove freezer plate and pour a mixture of baking soda and warm water down drain.
Posted on Nov 02, 2010
Adaptive defrost
What is the correct model number for your refrigerator? cea8a0b5-b4f2-4a25-8a64-0da338ab476f.jpg
If using the auto model number listing here on Fixya it will cause a wrong diagnosis. It is nearly impossible to help answer what may be happening without the correct model number. I am here should you need me, Thanks John Tripp Appliance 911
If you only have a refrigerator leaking then click HERE
Mar 11, 2014 | Viking VCFF036SS
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
Why is water leaking from front of bottom freezer?
Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? You have a defrost drain blockage.
We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! Not all blocke drains act the same when your refrigerator leaks so please ask should you have questions. Please provide the model number found around the fresh food section door frame. Kenmore model numbers look like this example=> 321.1234567 If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 26, 2013 | Whirlpool Refrigerators
Water is leaking on floor from left hand front corner (freezer side) I noticed it does it on the right hand corner at times also
On my fridge like this one, on the freezer side, down at the bottom (below the doors, where the vents are, there's a turn knob there. If you turn it counter clockwise, it'll unscrew filter. It's white and about 2" round and 10" long. It's the filter that goes to the water supply and ice maker. Mine had stopped up, I just pulled it out, went to home depot and got another just like it and re-plugged it in.. No more leaks for me!
Dec 07, 2012 | Frigidaire FRS26R4A Side by Side...
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
236 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
