Question about Bunn CWTF 15-3 Coffee Maker
Open the top. there is a trough drain that gets limed up. using a phillips head screwdriver, push through and twist, thereby removing the lime and ensuring proper flow. if water can't get through, it may overflow over the sides of the trough. also look behind the trough to the top of the tank and see if there is any water damage around the seals. if there is, replace the seals
Posted on Jan 15, 2015
SOURCE: adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Posted on Oct 05, 2009
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Posted on Oct 15, 2009
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
SOURCE: My Bunn coffee maker leaks out of the bottom
If you will call Bunn Customer Service, there is a seal kit that can be sent out to fix the leaking problem you are experiencing.
Posted on Jun 02, 2010
SOURCE: Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Posted on Oct 31, 2012
Feb 17, 2014 | Bunn NHB Coffee Maker
Feb 17, 2014 | Bunn 10 Cup Home Coffee Brewer
Jan 10, 2014 | Bunn CWTF 15-APS Coffee Maker
Jan 05, 2014 | Bunn CWTF 15-APS Coffee Maker
Dec 10, 2013 | Bunn CWTF 15-APS Coffee Maker
Nov 24, 2013 | Bunn CWTF 42 12-Cup Coffee Maker
Apr 17, 2013 | Bunn CWTF 15-3 Coffee Maker
Dec 27, 2010 | Bunn CWTF 15-APS Coffee Maker
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Jul 02, 2009 | Bunn CWTF 15-3 Coffee Maker
Jan 15, 2021 | Cuisinart Coffee Makers & Espresso...
105 people viewed this question
