Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
SOURCE: Rockford Fosgate 120a2 amp
You can get it from Rockford.
Let me know if you need any help repairing it.
Posted on Aug 19, 2008
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
SOURCE: wire my rockford fosgate rf2002 amp and 12"sub to cobalt
Hi my names Josh. I see you want put your rockford amp in. Assuming you have your factory radio you have some wiring to do. But first you need and amp kit it wil have the necessary wiring you will need in it to wire your amp to your car. You will also need a line level converter they you can pick on up at best buy other wise known as a pac converter. This will alow you to transfer the high level frenquency your radio puts out to a low level frenquency to go strait to your amp through a pair of RCA's thus giving you sound to your amp and then to the sub. Your wiring will consist of the ground which you will have to ground off the vehicles chasis no more than a foot from your amps designated location. Then you have you power 12v which is about a 4 gauge wire and will be fuzed and ran strait to the positive side of your battery and last will be your remote wire. Your amp will have a place marked remote on it that is strickly for you to wire to your radio/ignition source for powering the amp up when radio is on and powering it down when it is off. YOU MUST ISOLATE THAT WIRE with a 12 volt tester it will be the wire that is tied in to your radio to power only when your igniton is on and when you turn your key it should tell you if you know how to properly check for this wire. wants you istolate this wire you will want to tie into to it and then of coarse run it and tie it into your amps remote power again it will be marked remote on your amp. From there all you have left is tying in your line level convererter.. This takes some patience as you must make sure that you do isolate your sound left and right postive and negetive front and rear channels the line level converter will tie into either your front or rear channel but caution you dont get them mixed or you will not have a signal at all. Again my names Josh and i hope you are able to get it hooked up okay.
Posted on Mar 07, 2010
