When I plug my phone into the usb, my driver software tells me that the usb device is ready to use but the phone is unplugged. I've tried to find and download drivers for the phone but have had no success. When I hit sync on my phone, it tells me I have a connect failure and that I should check the cable connection but the connection is fine. I was able to sync my boyfriends phone, which is also an LG but not a Dare.
SOURCE: MTP Device Searching Preconfigured Driver Folders
I was having this problem as well, but solved it.
I, like others decided to just buy a USB cable for my VX9900 and use Windows Media Player for sync'ing. (I also have the Verizon Essentials program that I downloaded, but I like WMP better. No particular reason).
I was getting the installation messages and as soon as the MTP message came up, I got the "problem" message and it didn't sync.
What I did when I got the cable was to run the CD drivers that came with my cable. That may have been my mistake. I was bothered that the date of my driver was in 2005 since the phone came out late in 2006. So I looked at the name of the driver and it was something like C:\Windows\System32\Drivers\LGUSBDriver.xxx whatever... I went to my device manager and uninstalled the driver. I went to the C:\Program Files\ and deleted the LG USBDrivers folder. I went to the Windows/system32/drivers folder and there were three LG*.* files I deleted them. The next time I plugged the phone in and set it to sync, it worked. It's late and night and I may not have typed this really clearly, so feel free to contact me at bill (at) halfamind.com (because a half a mind is still a terrible thing to waste).
Bill Isles
SOURCE: I cannot sync my computer
hi first custamise your sync settings and try it thank you sir,,,,,,,,,,,,,,,,,rate it
SOURCE: can't sync phone
go to download.com and get the data for the phone. its a tiny file that makes your computer recognize that the phone is plugged in. of course.. VISSTA has to be more complicated. :) thanks microsoft
SOURCE: My compter does not regonize my LG Dare or Sd
In order for the phone to work with ur pc u have to set/change the connectivity.
Go into Phone settings, then Connectivity, then USB Connection Mode, then select either Mass storage or Data Service, to use Mass Storage you must have a Memory card inserted into the phone, then you can select mass storage and use your phone as an external hard drive/memory stick. In this mode u can only transfer pics, music, videos etc from pc to phone and vice versa via your Computer Windows Explorer.
It will not enable you to use the LG PC suite Application. To use the LG PC suite, you must select Data Service, then connect your phone to the PC via a USB port.
SOURCE: I cannot connect to my V CAST. When I plug my Dare
WITHOUT sd card
go to my music, sync
should get red screen that says connecting...
then
v cast mobile phone
internal memory
select what program you use to sync with wmp, media monkey etc.
if you cant get that far make sure you have needed drivers, if possible try with different pc and or different usb port and i did have a bad oem usb cable
