Connecting to a PC
By using the USB cable, you can transfer the aptured photos and videos to a PC.
Follow the steps below to connect the camera to a PC.
1. Make sure both the camera and PC are turned on.
2. Connect one end of the supplied USB cable to the USB/AV OUT port on your camera.
3. Connect the other end of the cable to an available USB port on your PC.
Setting the USB mode
Since the camera’s USB port can be set to
connect with either a PC or a Printer, the
following steps will allow you to ensure that the camera is correctly configured to connect
with a PC.
1. Press the menu button and use the Up/Down navigation buttons to select USB Connect, and then press the Right navigation button.
2. Use the Up/Down navigation buttons to select PC.
3. Press the func ok button to confirm the setting.
Transferring files to your PC
The computer will automatically detect the camera as a removable drive. Double-click My Computer icon on the desktop to locate the removable drive and to copy the folders and files in the drive to a directory on
your PC as you would copy any typical folder.
