SOURCE: Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
SOURCE: I need to downgrade to previous firmware for
Unfortunately, once you install a firmware upgrade it is permanent. Driver updates can be reversed but not firmware. That is why you should always have a definite reason for upgrading the firmware.
SOURCE: spl-c error - including corrupted data (printer Samsung)
SPL-C -Incomplete Session by time out
Position : 0xddde (56798)
System : src/os_hook
Line :1646
Version : SPL-C 5.35 11-20-2007
Any one can help me how to fix this Error please.
