Question about Lexmark X75 All-In-One InkJet Printer
Lexmark x4270 print head maintenance
Only a blue color prints
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: no color printing with lexmark x4270
Actually your printhead on the cartridges is probably clogged. I usually take the cartridges out, wet a paper towel and put in a dish and put in microwave for 20 seconds, then put the cartridge printhead on the paper towel for 10 seconds, and then blot with a dry towel. You should see the various colors in the color and black cartridges. Do it several times until ink in freely flowing. Put back in printer and run a clean cycle and try printing normaly. For additional help: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS18888&relevance=1
Posted on Mar 07, 2007
Geraldine Watts
  • 390 Answers
SOURCE: Lexmark X4270
Have you told your pc the fax equipment you want to use, and does it appear in the device managers list?
Posted on Feb 12, 2008
Geraldine Watts
  • 390 Answers
SOURCE: blurry printing fro lexmark x4270
May be too much info blocking up print memory. Before printing off sites, make sure you clear print queue and slect printer friendly versions. Check to see if your printer has a work online or offline setting in preferences too.
Posted on Feb 14, 2008
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark x4270 all-in-one problem with Windows 7
    I really appreciate your patience. Thank you for choosing Lexmark glhall53!!!
    Posted on Apr 29, 2010
    printmastert
    Lexmark
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: Lexmark S405 won't print or
      Please visit the Lexmark support page to determine if your printer is affected with the printhead issue. Also, make sure your printer is updated. The firmware update will help give you a highly reliable print system.
      Click here to validate your serial number and/or update your firmware.
      Posted on Sep 26, 2011
      Pro901 stopped printing in color
      Blocked print head nozzles
      Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
      Try the printer maintenance to clear the printer nozzles.
      After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
      A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
      Nov 16, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
      Lexmark S405 isn't printing color when I just bought new cartridges.
      Make sure that you're using genuine Lexmark cartridges. Also, check if the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
      Performing a maintenance on the cartridges would also help. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
      Oct 29, 2012 | Lexmark X4270 All-In-One InkJet Printer
      Printer has stopped printing blue
      Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
      Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
      Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
      If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
      If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
      Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
      Lexmark X75 won't print in color. Tried cleaning print heads, didn't work. What now?
      Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
      If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
      It may be more cost effective to buy a later model and better printer thanreplace the print head.
      Jun 16, 2011 | Lexmark X75 All-In-One InkJet Printer
      I cannot print --lexmark x4270. Replaced both cart color and black. What have I done--will scan but not print. Thanks
      Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
      Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
      If that does not work then follow the next step.
      Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
      Jan 06, 2011 | Lexmark X4270 All-In-One InkJet Printer
      Lexmark z615 only prints black and blue no other colour It is a new cartridge
      The print head for the other colours may be blocked.
      Try the clean print head maintenance a few times. You may need to replace the print head.
      Sep 21, 2010 | Lexmark Z615 InkJet Printer
      How do I get my color ink to print on Lexmark x4270 series
      Most drivers default to color. In Windows, go to your printer folder, right click the driver and click on Properties. Check the settings to see if color is selected as default.
      If it is color, your application is overriding the driver color settings and would have to be changed in that before printing.
      Sep 10, 2009 | Lexmark X4270 All-in-One Multifunction...
      Lexmarkx4270 all-in one
      Remove the black ink cartridge and examine the print head on it - you will probably find a small piece of tape (very thin) covering the jets - usually blue in color - remove it and reinstall the cartridge.
      Nov 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
      Color Printing
      from the lexmark toolbar check to make sure color is selected not black and white
      Oct 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
      Lexmark X75 All-In-One InkJet Printer Logo
      Top Lexmark Office Equipment & Supplies Experts
      Muntejaya Ginting
      Muntejaya Ginting
      CheckitRight
      CheckitRight
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
