SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
SOURCE: soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
SOURCE: GE TRITON XL REPLACEMENT SOAP DISPENSER?
Best way is to call GE Part at 1-800-626-2002 or go online to www.geappliances.com
SOURCE: Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
SOURCE: Triton XL GE Profile Dishwasher does not wash dishes well, but in particular, leaves a cloudy film.
we have a ge trinton xl dishwasher and it is doing draining....I have seen several blogs on repair assistance refer to the drain hose...where is the drain hose ??
