Sony wega kds r60 sxr1
I have a Sony wega tv is a kds r60 sxr1 bit anyways I have solid barrs going from top to bottom I changed the bulb thinking that was it but no luck any ideals I don't know if that could be anything to do worth the optical block or not
Posted by gilder399 on
suvan
    New Friend:
    Problem Solver:
  • 15 Answers
Hi is it connect to a dstv decoder, if so try unplugin the decoder from the tv and see if the lines are still there, if not it could be the decoder thats causing it.
Posted on Feb 18, 2014
3 Related Answers
Anonymous
  • 105 Answers
SOURCE: optical block
the optical assy is a large amount of work i wouldnt recomend doing it yorslf at all. please leave that to the pros. you have to completely disassemble the tv from the back. i can do it myself in about 45 min.
Posted on Oct 13, 2007
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
Posted on May 02, 2009
Raditronic
Radames Pagan
  • 196 Answers
SOURCE: Sony grand wega 42 with red area on top and blue area on bottom
bad optic unit block
Posted on Apr 21, 2010
How to replace lamp sony sxrd projection tv model no. KDS-55A2020
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Jul 07, 2014 | Sony XL-5100 Projector Lamp for Grand WEGA...
My kds-r60xbr1 sony wega projection tv is blinking green then red and wont go on how do i fix this problem .i also just replaced the bulb about 3 months ago.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a sony grand Wega KDF-kdf50e2000 and when you turn the TV on it will work fine for 40 seconds and then go off with the green power/standby indicator flashing. After 40 seconds the TV will come back...
If this is the model I am thinking of, Sony has a recall on the light engine. They are going bad in many of the Grand Wegas. Call them up and they should offer a new tv. You can either get a BRAND NEW lcd tv for free, but it is going to be smaller than your current one. Or you can get a different size for a reduced price. Late last year (november 2009) my grandma saw a red band at the top of the display. We called up Sony and we got a BRAND NEW 46" 120hz Sony Bravia for about $250 if I remember correctly. And since it is a new tv, you get a new warrenty. You also get to keep your current grand wega because they simply don't want them. I stongly recommend calling them up because this will give you a new tv. Spread the word.
Jan 02, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a Sony KDS 55A TV.
Please check color temperature adjustment in menu and also check white balance adjustment.
Jul 23, 2009 | Sony KDS-55A2020 55" Television
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Recall?
    I really need some help with what/who do I need to contact to resolve the problem. My light bulb went out first and now the Light Engine is going out. Causing a blue screen bar screen in the bottom half of my TV and little blue dots everywhere on the TV. I have the 60' Sony Wega Model
    Apr 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Sony KDS-R50XBR1 shutting off
    When the lamp becomes weak in this Sony the unit will shut off intermittently. I would replace the lamp and use only an OEM Sony lamp, not an LTI or other knock off. The knock off lamps are of poor quality in my experience and opinion.
    Apr 15, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Televison & Video Logo
    47 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
