Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
  • Anonymous Jun 30, 2009
    It has red blue and green squiggly lines through the picture
Anonymous
I belive that the red light means that it is off and the blue means that its on
Posted on Jun 30, 2009
My RCA big screen picture messed up after one of my children fell nto screen?? How can I fix this
The picture on my 52 inch RCA Projection television has green, red and blue squiggly lines around the objects on the screen and the picture looks 3-D.
The rca 52 inch tv turns on with picture but the images are in split in three with red green and blue and theres about five lines that swoop down and up to the top of tv ?
the ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com usually repairs that issue. The kit contains the parts and the CD with instructions
2helpful
52 inch rca projection tv turn tv on and there are horizontal
Go to menu then setup look for convergence if you Do NOt see convergence then you have a open fuse FL231 Located on right side of FBT there is 3 in a roll small brown rectrangle looking caps but they are Fuses it will be in the one in the middle.
HDTV 52 inch RCA projection
The red picture tube is shorted. Huge job! Maybe not worth doing.
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
2answers
53 inch panasonic projection tv. have sound screen is black with red green and blue sqiggly line in middle. what is it and how much to fix
check the yoke plug solder joint, as the squiggly lines in the middle usually happens if the yoke is unplugged. So check the yoke plug connections.
3helpful
3answers
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
2helpful
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Top Zenith Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
