Question about Kodak EasyShare C360 Digital Camera
Camera keeps saying memory card is protected, but its unlocked
5 Suggested Answers
Anonymous
  • 114 Answers
SOURCE: "Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Posted on Aug 29, 2005
Anonymous
  • 53 Answers
SOURCE: MY MEMORY CARD WHEN INSERTED SAYS:PROTECTED IMAGES
there should be a little swith on the side of the card. switch to the opposite and then try
Posted on Aug 26, 2009
Testimonial: "Thank you! You fixed my problem!"
Anonymous
  • 63 Answers
SOURCE: It says my memory card is protected
On the side of the memory card, there is a small slider that locks and protects the memory card from being overwritten. Yours may be in the locked position. Simply pull out your memory card form your camera and unlock your memory card by sliding the tab.
Hope this helps,
Andrew
Do not forget to vote.
Posted on Apr 09, 2010
Anonymous
SOURCE: Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Posted on Jun 11, 2010
Ty Price
  • 11967 Answers
SOURCE: When I turn my Kodak
Move the slide switch on the side of the card to "unlocked"
Posted on Aug 10, 2010
Why does my s120 keep saying memory card write protected?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 23, 2012 | Sanyo VPC-S120 Digital Camera
My fujifilm jv200 camera keeps saying protected card.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 05, 2012 | Fuji Cameras
It keeps saying card protected everytime I try to record. I downloaded my videos on my computer and tried to earase the card and it keeps saying card protected.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 04, 2011 | Aiptek IS-DV2 Camcorder
Camera keeps saying "card locked"
May 20, 2011 | Casio EXILIM Digital Camera
I'm trying to delete a photo that i had taken and it keeps saying card lock what does this mean and how can i unlock it?
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 05, 2010 | Cameras
L100 Digital Camera: keeps saying card locked...
May 17, 2010 | Samsung L100 Digital Camera
Message that says protected card will not let me take a picture. What should I do?
Apr 24, 2010 | Fuji FinePix S700 Digital Camera
Hope this helps,
Andrew
Apr 09, 2010 | Kodak EasyShare One Digital Camera
Says this memory card is protected - can't take
Kindly follow the steps below
Remove the memory card from the camera.
Look at the memory card very well, you will see a slide switch on the side edge of the memory.
Move the switch to the unlock position.
Put the memory card back to the camera.
You can then start using it.
Thanks
Oct 16, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
My memory card in my camera keeps saying its protected
Hi there, My name is Rob and I can help you. Do this:
Make sure the camera is off and pull out the SD card. Look on the side of the card. You will see a little switch. One side says locked (or shows a little picture of a locked lock) the other side says unlocked (or shows a little picture of an unlocked lock). Make sure the switch is in the unlocked position and reinsert it properly into the camera.
This will fix your problem. Thanks for coming to FixYa. Let me know if I can be of anymore help. Don't forget to rate my answer a fixya!
Rob
Feb 23, 2009 | Fuji FinePix S304 Digital Camera
Kodak EasyShare C360 Digital Camera Logo
27 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
