Question about Kenmore 30-pint Dehumidifier with Electronic Controls
I don't understand the timer on a Kenmore Dehumidifier
It has a timer for auto start and auto stop, however, from the looks of it I can't set it to be consistent each day???
Posted by jason on
J.D. Browning
  • Kenmore Master
  • 2,760 Answers
I do believe this one of those models that uses one display for both setting of humidity level and the timer , make sure you are viewing the timer function and not the humidity function , this is a very common complaint with these type as many times one sets the on time correct but then sets what they believe to be off time when they really are adjusting the humidity room level , there should be tiny lights that show function you are adjusting
Posted on Jun 06, 2015
1 Related Answer
Anonymous
SOURCE: Auto-off light keeps flashing
I have the same issue.  Any responses?
Posted on Jul 06, 2008
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
How to set timer on 2014 Kenmore 50 pt Dehumidifier
if you hold mode button down does it not cycle thru timer settings?
May 24, 2014 | Kenmore 30-Pint EnergyStar Dehumidifier
Kenmore model 580.54351800 ices up quickly, doesn't defrost, and as a result doesn't dehumidify. Bad thermistor?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 12, 2011 | Kenmore 54701 Dehumidifier
Kenmore 54341900 dehumidifyer compressor stays on too long and freezes up. humidity control is rusted up
heatman101
Sep 10, 2011 | Kenmore 54351 Dehumidifier
I have two of these dehumidifiers. They won't go on automatically. I don't understand the settings. One of them won't stay on at all. It runs and then shuts off.
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier. Hope this will help you. Good Luck.
Jul 08, 2011 | Haier 65-Pint Dehumidifier
Have classic dehumidifier model#CDR4500E. Can't adjust it automaticaly to come on or shut off. Don't understand the keypad fuctions, booklet to confusing.
Your dehumidifier preset default humidity level of 70%. Which is rather high, if you're using the unit in the hot Summer months. You can override this setting and lower the humidity level in increments to as low as 35%. Which is ideal during hot, humid weather. The Air Down button lowers the humidity level.Once the level is set, the unit will cycle ON and OFF as necessary, to maintain the level of humidity.
I have looked at the Owners Manual for you unit, and it's very thorough. But, I can understand, if you're not familiar with how the units work, it could be confusing. Page 5, is very informative on how to operate the unit, as far as setting humidity levels, which is what's important. If the operation of the unit continues to be a problem for you, contact Danby Customer Support 1-800-263-2629 and they can walk you through the procedures, while on the phone with them.
Hop this helped you. Please let me know. Thanks.
May 18, 2011 | Danby DDR2509EE Dehumidifier
Jul 03, 2008 | Kenmore 54351 Dehumidifier
Kenmore 54701 (70 pint) dehumidifier stopped running
the lowest setting for % of humidity is 35% on that unit... sounds like with all the other errors that the IC board is bad (the Control circuit board behind the displays)
Nov 25, 2007 | Kenmore 54701 Dehumidifier
Kenmore 30-pint Dehumidifier with Electronic Controls Logo
213 people viewed this question
Top Kenmore Dehumidifiers Experts
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
