Question about Sony PlayStation 2 Slimline Console
Ps2 not playing ps1 games invalid format - Sony PlayStation 2 Slimline Console
Anonymous
SOURCE:
Cerfer39
Greg Stokes
  • 709 Answers
SOURCE: My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact [email protected]
Posted on Nov 05, 2007
Anonymous
  • 3 Answers
SOURCE: ps1 games
Are you receiving a disc read error? Or do they simply not load?
In either case, you will want to make sure that your laser is clean. This will require opening the console.
Just google playstation 2 repair and look for free walkthroughs...they are everywhere.
I would boil the problem down to 3 possibilites....
1. Alignment
2. Adjustment of the cd side of your laser potentiometer
3. A simple cleaning of your laser
Posted on Nov 15, 2007
Arucardo
Arucardo
  • 10 Answers
SOURCE: ps1 disc playing in ps2
Are you inserting a PS2 or a PS1 memory card?
PS1 games can't use a PS2 card because they don't "understand" how to read them.
To save a PS1 game on a PS2 you will need a PS1 memory card.
I hope this helps, I assume this is what you are referring to with your question.
Posted on Jan 02, 2008
Anonymous
  • 6 Answers
SOURCE: 60GB PS3 will play PS1 and PS3 games but not PS2.
this is a problem with some ps3's especialy the high GB ones like mine. they made it so most if not all of the ps2 games cannot be played to cut down on price and to leave room for all the memory. so you can still play ps1's but you cant play ps2's. sorry
Posted on Jan 08, 2010
Anonymous
SOURCE: PS2 reads ps1 games but not ps2. Clicking noise
I have trash picked 2 of them and fixed this same problem. Just be prepared to spend some time and be patient. Clean the lens with glass cleaner. Under the lazer is a white gear it turn it two clicks clockwise and try a ps2 game. If it does not work turn it another 2 clicks. 4 clicks seems to be the magic number, after 4 clicks go only one click at a time until the game loads.This has worked numerous time for me. just keep track of how many clicks you do in case you want to bring it back to the original setting for some pointless reason. Good luck.
Posted on Feb 17, 2010
How to fix rsod on pcsx2 0.9.7
The infamous Red Screen of Desk -- A.K.A. Insert a Format Disc screen.
This screen is NOT asking for a disc to FORMAT the PS2. What it IS asking for is a PS2 or Playstation format [or a better word -- PS2 or Playstation TYPE disc. A disk with Playstation 1 or Playstation 2 type software on it -- in other words, a ps1 or ps2 game]. It's basically asking for a CD or DVD with software that the playstation can play. This red screen occurs when you insert an XBOX game or a burned/copied PS2 or PS1 game. What the PS2 is stating is that is cannot play this format [or type of] disc. It's asking you to insert a format [or type of] disc that it can recognize and use.
The most common reason for this screen appearing, if your PS2 does NOT have a mod chip, is a dirty lens. Try cleaning your lens and this should go away. What happens is that the lens becomes dirty and does not recognize the disc you inserted as being a PS2 or PS1 format [or type of] disc. So it's asking you to insert one. If your PS2 does have a mod chip installed, it could be a problem with the chip or the disc you burned. We don't install or sell mod chips, so we can't help you with that one.
May 20, 2012 | Sony PlayStation 2 (PS2) Console
How to fix rsod in pcsx2 0.9.7
The most common reason for this screen appearing, if your PS2 does NOT have a mod chip, is a dirty lens. Try cleaning your lens and this should go away. What happens is that the lens becomes dirty and does not recognize the disc you inserted as being a PS2 or PS1 format [or type of] disc. So it's asking you to insert one. If your PS2 does have a mod chip installed, it could be a problem with the chip or the disc you burned. I don't install or sell mod chips, so I can't help you with that one...
Hey, do you know, in my country Malaysia we got someone that can upgrade PSOne console to be able to play PS2 console game :) but I wonder, how they do that...?? That the problem, and I wish someone who...
The only way someone can get a PS1 to play PS2 games is if they modified a PS2 to look like a PS1. The hardware inside a PS1 is not powerful enough and not complex enough to run PS2 games. They would need to take a PS1, and take the insides out. Then take the insides of a PS2 and modify it so it functionally fit inside a PS1. This seems like cool albeit pointless way to modify your PS1 and PS2. Thanks for the question!
May 30, 2011 | Video Game Consoles & Games
Can ps2 games be played on ps3
on the first ps3s but not now......im not sure bout the slim......mine plays ps1 2 3
Nov 11, 2009 | Sony PlayStation® 3 (60 GB) Console
What games beside ps3 games are compatible with the ps3
It depends on your system the 40g will play ps1, but not ps2. The 60g or above will play both.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Ps1 games
your slimline might not normally play the games Use swap magic it should have two discs one for booting PS2 games and one for booting PS1 games you simply put the appropriate swap magic disc and then the game you want to play
http://www.swapmagic3.com
This is what it states under What games support Swap Magic 3?
Swap Magic 3 support almost all SEGA ROMS, SNES ROMS, PS1 & PS2 Games!!
Feb 23, 2008 | Sony PlayStation 2 Slimline Console
Ps1 disc playing in ps2
Dec 25, 2007 | Sony PlayStation (PS) Console
Can't read my disk, grinding sound
they are a compaq format. some ps2s only read dvd rom formats. check the back of the cd case
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Playstation card
Your question is somewhat confusing, using a playstation 2 memory card, will have PS2 game saves on it, how would you play PS2 games on a PS1 from the save, you can't. If you just mean you are using a PS2 card for a PS1, the way a PS2 card saves data is different to a PS1 card, so it probably won't work You can use your PS1 memory cards in the PS2. You can only use the PS1 memory cards to save PS1 games that you are playing in your PS2. You can't save any PS2 game data to a PS1 memory card
Oct 05, 2007 | Sony PlayStation (PS) Console
Sony PlayStation 2 Slimline Console Logo
212 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
