Question about Brother MFC-7820N Laser Printer
Heavy black line on right margin
I switched to a new OEM cartridge (my compatible cartridges gave dirty results) and the pages print with a 1/4" line on the right margin.  Any solution?  Thanks
Posted by Canton on
  • Anonymous Feb 23, 2008
    when scanning a document I am receiving a black line through the middle of the page. It is perfectly straight, almost looks as if it was meant to be there it only shows when using the feeder. The line does not show up if you scan the document on the flatbed anybody have any knowledge or suggestions on what it could be
Soulvisitor
  • Brother Master
  • 1,113 Answers
Check corana cleaner is in home position, it is a blue tab on drum that slides width of drum to clean charge wire, try sliding up and back a couple of times and make sure it sits at home position marked with an arrow.
Posted on Oct 28, 2007
  • Soulvisitor
    Soulvisitor Nov 01, 2007
    Replace drum cart,not the same as toner cart
    If you pull out drum you should see your mark on it, wiping it will not help.It has a rubber blade that is not doin it's job (probally stuffed up with dodgy toner)
    Slight outside chance it is fuser but looking at drum will tell.
    Thats it Toner/Drum?Carona/Fuser  (laser glass/shutter stuck are super rare very outside possibilites)
  • Soulvisitor
    Soulvisitor Dec 21, 2007
    you did say on prints, Solution is different if occurs on copys
My printer suddenly prints all black pages.
are you using 3rd party cartridge if so replace them all with OEM cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 28, 2015 | Office Equipment & Supplies
I replace my cartridges it says refer to printer documentation and will not print
These types of severe HP 74 black or HP 75 color ink cartridge errors (i.e. refer to documentation / incompatible cartridges, print cartridge(s) problem, etc.) typically indicate the internal micro electronics of the respective HP 74 black or HP 75 color cartridge are damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal micro electronics failure. I suggest you first run a Tap 41 diagnostic test to check cartridges electrical health (this is a special forced service test, refer to video so you understand how to read the print out). You may also bypass the error (temporarily) on most models which use HP 74/75 cartridges.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report: http://inkjet411.com/?page_id=536
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
NOTE: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
ERROR BYPASS OPTION (TEMPORARY ONLY):
NOTE: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
*Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active electrical state of both cartridges.
For additional printer diagnostics information please visit: http://inkjet411.com/?page_id=1813
NOTE: If you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (with ink compatibility or color output/richness) with all of these models: http://inkjet411.com/?page_id=3585
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 74/75 original/genuine ink cartridges is only suggested!
HP 74/75 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=WqnHRFpbo0w
If you ever need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty and free shipping over $20 (products available to US residents only).
HP 74 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2074
HP 75 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2075
For any additional questions please contact us directly: [email protected]
-Thank you
May 21, 2015 | HP Photosmart C5280 Printer
My hp envy 5530 is only printing half a picture
If it is only printing the top half then it is quite possible you are running out of ink. Try printing on only black and see if this works. When is the last time you replaced the colour cartridge?
Feb 25, 2015 | HP ENVY 5530 e-All-in-One with 2-month...
Hp J5780 all in one - I cannot get the printer to attach to the bottom portion.
Regarding your recent inquiry about the HP 74, 75, 74XL or 75XL ink cartridge error message ("Cartridges Not Aligned" or similar printer alert condition) and inability to print with your HP OJ J578 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside one of the ink cartridges (.....it is very rare for both cartridges to fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, and to confirm/determine which of the two ink cartridges is causing the failure condition, please run the 'Tap 41' cartridge's electrical diagnostic test below (refer to C.)
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
DIAGNOSTIC STEPS:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Print Extended Self Test:
    1.Press CANCEL + OK buttons at the same time.
    2.The extended self test page should print.
    --- Verify all colors and all stair-step nozzles are firing (i.e. no missing horizontal lines should be visible in the stair-step grid patterns). (NOTE: the self test page is a 'forced' test print whether the ink cartridges are good or bad). Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
    C.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure (or .pdf document) at the following links on how to activate and read the service test:
    http://inkjet411.com/?page_id=544
      1.Press the * and # keys simultaneously.
      2.Enter 124 (or 123) at keypad.
      3.Use the arrow keys to navigate to the System Menu. Select Ok.
      4.Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Should display 'code = 0'.
      5.Use the arrow keys to enter 'code = 41' (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern should begin to print.
      NOTE 1: The 'Tap 10' (extended self test) can also be activated by pressing CANCEL + OK buttons at the same time. Whether ink cartridges are good or not, i.e. this is a forced print test). Refer to following 4 paragraphs (or video) on how to interpret diagnostic report.....
      NOTE 2: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
      NOTE 3: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions. However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced:
      D. Cartridge Error Bypass ( Emergency Printing Only - http://inkjet411.com/?page_id=544 ):
      1. Press the * and # keys simultaneously.
      2. Enter 123 (or 124) at keypad. The 'Underware' menu should be displayed.
      3. Use the arrow keys to navigate to the Information Menu. Select Ok.
      4. Use the arrow keys to navigate to the 'checksum for relock data input'. Select Ok. LCD should display a 5-digit number after a few seconds.
      5. Attempt to send a print job to printer
      NOTE: with a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
      *Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active state of both cartridges.
      For reference, the following page provides a complete review of the majority of cartridge error messages you may observe on your printer at one point or another:
      http://inkjet411.com/?page_id=509
      However, if your printer works routinely after inserting a brand new HP 74 and/or HP 75 ink cartridge in it, then this will confirm root cause of failure as being limited to one of the ink cartridges.
      For additional HP OJ5700 printer series diagnostics information please visit: http://inkjet411.com/?page_id=1813
      If you need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty (remanufactured ink cartridges which have been thoroughly tested; purchases are only available by USA residents).
Feb 17, 2015 | HP Officejet J5780 All-In-One InkJet...
How do I by pass align instructions
Regarding your recent inquiry about the HP 61 black.....OR....HP 61 color ink cartridge error message and inability to print to your HP ENVY 5530 printer, this type of problem could be an electrical connection issue between the printer and the cartridge (i.e. dirty electrical contacts on either the cartridge or printer carriage flex cable surface), or more likely, an internal micro-electronic failure inside one of the HP 61 ink cartridges (please note it is very rare for both ink cartridges to fail at the same time - hence one of them is likely causing the current issue).
To determine which cartridge is causing the error condition and to check the electrical health of both ink cartridges, please run the 'Tap 41' diagnostic test below (PROCEDURE B.).....
NOTE: If the LCD screen is 'frozen', then one of the ink cartridges is likely suffering from marginal internal electrical performance and may need to be replaced - SEE DIAGNOSTIC STEPS BELOW. Please visit: http://inkjet411.com/?page_id=396
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
An internal electrical failure of a cartridge can be confirmed by performing the following steps which will help rule out other variables which could also be causing the issue.
DIAGNOSTIC STEPS:
[HP Deskjet 3510/3512/3520/3051A/3054, ENVY 4500/5530 & Officejet 2620/4630/4635/3512 MODELS]
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test (refer to 2nd video at the following link so you understand how to analyze the test print - though you will use steps 1 thru 6 below to activate the test report): http://inkjet411.com/?page_id=1476
    1.Using two fingers, gently tap the 'Return' and 'Home' keys on touchscreen until the 'Support' Menu is displayed (for example, press the button 3-4 times each in alternating succession).
    2.At 'Support' menu, select the upper right button until the 'Reports Menu' is visible. Select OK.
    3.Press upper right button until 'print mech button tap' menu is displayed.
    4.Press OK, the 'code = 0' menu should be displayed.
    5.Use arrows keys to change value to 'code = 41' (i.e. press and hold right arrow key). When 'code = 41', select 'OK'. NOTE 1:The Tap 10 self-test print may also be initiated via 'code = 10'
    6.The diagnostic 'tap 41' test report will print. (see video here: http://inkjet411.com/?page_id=1476 )
    -- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health. A good HP 61/61XL color cartridge should display 612 good nozzles, while a good HP 61/61XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced.
    ---If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink. Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one (or both) of the ink cartridges is damaged.
    C. Print the Self Test Page (HP TOUCHSCREEN MODELS; when cartridges are functioning normally with no cartridge errors):
    http://www8.hp.com/h20621/video-gallery/us/en/customer-care/printers-and-all-in-ones/general-troubleshooting/2825521889001/Printing%20a%20Test%20Page%20-%20HP%20Envy%204500%20e-All-in-One%20Printer/video/
    1. Load plain white paper in the input tray.
    2. At printer's LCD screen, navigate to TOOLS menu.
    3. Choose 'Printer Status Report', - the self-test report should print.
    *Many cartridges eventually do encounter problems or failures. The "Incompatible Cartridge(s)" / "Print Cartridge(s) Problem - Refer to printer documentation."error message is typically indicative of failed micro-electronics internal to the ink cartridge(s). Also, it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active state of both cartridges.
    For reference, the following page provides a complete review of the majority of cartridge fatal error messages you may observe on your printer at one point or another: http://inkjet411.com/?page_id=415
    If your printer works routinely after inserting a brand new HP 61/61XL black.....OR....color ink cartridge in it, this will confirm root cause per the suspect ink cartridge.
    For advanced printer diagnosis please refer to .pdf file at the following Inkjet411 support link: http://inkjet411.com/?page_id=1813
    Unfortunately the micro-electronics in many of the newer HP 61 integrated ink cartridge lines are quite fragile (due to low-cost materials used in the manufacturing processes), so results of repeated cartridge usage/longevity will vary from one extreme to the other. As a suggestion, if you print more than 15 pages per week, then you may want to consider moving over to an 'individual ink tank' printer system....these are very "refill friendly" and you will not encounter cartridge failures. For information on REFILL FRIENDLY printer models please visit our support site: http://inkjet411.com/?page_id=3585
    HP 61/61XL Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=-3yRzrIVM9w
    If you ever need to purchase a new HP 61 ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (purchases available to USA residents only). These are refilled original ink cartridges which have been electrically bench tested to guarantee satisfactory performance.
    For any additional questions you may have please contact us directly: [email protected]
Feb 04, 2015 | HP ENVY 5530 e-All-in-One with 2-month...
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Small black lines print at the right side margin
Good day!You can clean the drum of the cartridge by wiping a clean cotton in it..mybe its dirty on that part..
regards,
mastergani
Mar 21, 2010 | Office Equipment & Supplies
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Brother MFC-7820N Laser Printer Logo
121 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
