SOURCE: Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
SOURCE: WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
SOURCE: The picture on our Mitsubishi
http://servicemanuals.vstore.ca/product_info.php/pName/v26-chassis-block-capacitor-kit for $115 This kit does all the caps in the chassis.
SOURCE: MITSUBISHI 65813 SCREEN GOES TO BLUE ABOUT 2 MINUTES AFTER TURNIN
try to look at its circuit board and look for some cold solder
SOURCE: green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
