Question about Olympus SP-350 Digital Camera
I havea kodak M1063 my instrction booklet tells me how to get to the date stamp but I do not know how to change the date
1 Related Answer
Anonymous
  • 919 Answers
SOURCE: DATED STAMPED
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Posted on Jan 22, 2009
I have a Kodak EasyShare C143. I would like to have the date stamped on my pictures and am unable to get this to work. Please help!
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
HOW TO SET DATE STAMP ON PICTIRES
Press the MENU button. Use left/right to select the Capture tab. Use up/down to select the "Date Stamp" item and press the OK button. Select "On" and press the OK button.
2helpful
How do i change the date stamp on my camera? Kodak Easy Share m1093
  • Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial.
  • 2
    Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu.
  • 3
    Press the "Down" button to change the selection to "None." This removes the date stamp.
  • 4
    Press "OK" to save the setting. Press "Program" to return to capture mode.
  • 7helpful
    How do i turn OFF the date stamp on my kodak M1063? i've been through the menu several times. help!!
    Directions to switch the Date stamp off:
    • Menu
    • Camera Settings
    • Date stamp (logo is like an old fashioned stamp)
    • Choose OFF
    Just got a new camera & i cant set the date & time Its a M1063
    Menu: Cam. Settings: Date and Time.
    It also appears automaticly after resetting:
    Reset cam: Take the batt out for longer than 15 sec and reinsert.
    Contact KODAK:
    http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
    Date/time setting
    These can be set in the setup menu.
    4helpful
    Can't reset Date & Time
    What you have to do is go to the icon with the spanner (as shown above) and keep tabbing down. There are more options than just the ones you see in the screen (not just High Power , Auto, Set Tag, On), keep going down and it will show you the other options. You will see the date change icon about 7 or 8 down.
    1helpful
    Can't find date on language settings on my m1063 kodak easyshare camera
    Turn camera ON lens will come ON
    Press Menu scroll far right,
    Keep scrolling down untill you get to Time and date.
    Press Zoom and read help menu.
    Set time and date and functions.
    Vitally
    2helpful
    2answers
    Removing the date stamp on photos
    If you mean, removing the date stamp after it's already on the picture -- the only way I know of is the hard way, using image processing software such as Photoshop to change the date stamp pixels to the surrounding color.
    If you mean, turning off the date stamp option so it doesn't get added to the picture in the first place -- I'm not familiar with your particular camera but the first place I'd look would be in the setup menu.
    Olympus SP-350 Digital Camera Logo
    Top Olympus Cameras Experts
    Steven Wander
    Steven Wander
    Ekse
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
