OCE FX3000 Missing the OCR Software
I have downloaded the Multifunction Suite for my Windows 7 and all but the OCR Software was included. Is there a free OCR Scan Soft Paper Port OCR software available?
Posted by Norris Johnson on
Dustin
    Master:
  • 350 Answers
5 Related Answers
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: ocr WHERE DO i download the soft ware for my lexmark
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Here is the link to download the software
Posted on Feb 08, 2009
Anonymous
  • 20 Answers
SOURCE: Lexmark X2500 driver is missing OCR software
Sometimes companies only support only the basic drivers. The OCR software is on the CD (s) that came with the printer. Suggestion. Try to order the original CD from Lexmark., or search Ebay for programs that have OCR capability. You can use OCR programs from other vendors as long as they are stand-a-lone programs. Just make sure you have the original disc so as not to infringe on copyright privileges.
Note: you can buy OCR programs. Check Ebay and Amazon. They are usually better that the programs that come on the OEM disk.
Cheers.
Posted on Mar 27, 2009
Anonymous
  • 53 Answers
SOURCE: ocr software missing. did not scaning
You can install the OCR software from the CD. Run the Setup and you should probably see an option to install "Additional software". Choose "Abbyy...", this is the OCR software you need.
If you don't have the CD anymore you will probably have to call Lexmark Customer Support to order one. I don't think the OCR software is available for download.
Posted on May 21, 2009
Anonymous
  • 53 Answers
SOURCE: Need lexmark 8300 OCR software
Try this and let me know http://download.cnet.com/Lexmark-8300-Series/3000-2116_4-189010.html
Posted on Aug 26, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
    Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
    Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
    If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
    Posted on Feb 14, 2012
    I cannot get my oce fx3000 printer to print
    After you install the New Drum unit you need to reset the drum counter to be able to use the Oce FX3000 again. Open the front door cover (the one you open to replace the drum or toner ctg.) On the control pabel hit the clear/back key. The display should say something like reset drum? Hit 1 for yes, close the door and you should be up and running again.
    Oct 08, 2014 | Canon Genuine Oce Imagistics Fx3000...
    I need OCR for MFC J220,how to get it?
    Go to the Brother Solutions Center for your country or region. In the download page, download the full software suite for your OS. It should have a version of the ScanSoft application.
    Aug 15, 2014 | Brother MFC J220 - multifunction fax /...
    My Canoscan 4200F has no OCR software. How do I get it?
    OCR software is usually a third-party program. Sometimes it is available on the original driver CD but it isn't included in the downloaded driver software. In the case of the CanoScan 4200F, the CD included the OmniPage SE OCR program. The SE indicates a Special Edition only bundled with the scanner and was only available for the OS versions that had been released when the scanner was first available. If you have the original CD (for Win98-XP), try to install the program using the Custom install option. (Check your current OS version. A 32-bit OS is more likely to support the OmniPage SE. With Windows Vista and 7, click Start > Control Panel > System and Security > System to determine the version. x64 indicates a 64-bit OS. ) If your current computer doesn't have an optical drive, use an external optical drive to install the program.
    If you do not have the CD or your OS is incompatible with the Omnipage version on the CD, you will need to either purchase OmnuPage ($99 with a rebate from many vendors), AbbySoft's OCR program or one of the other OCR programs. SimpleOCR is free for personal use, http://www.simpleocr.com/Info.asp . The biggest problem with the free OCR programs is that they do not handle documents with columns properly.
    I wish that I had better news for you.
    May 31, 2012 | Canon CanoScan 4200F Flatbed Scanner
    W810 sony ericsson pc suit software
    you can download this file
    sony erricson pc suite 6.011.00http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/w810i?cc=ca&lc=en
    download the PC Suite software for w810 and install it on ur windows 7 pc. i took out my w810 and tested it with my windows 7 for you and it works. sync is working with outlook too. missing my w810
    Feb 16, 2012 | Sony Ericsson Walkman W810i Cellular Phone
    Feb 13, 2012 | Lexmark X Office Equipment & Supplies
    I have a lexmark x5650 my operating system is windows 7. I broke my cd so i had to download the software from the website. When I try to scan something it says ocr application missing.
    The Lexmark OCR scan software is available in the install disk only. Please contact Lexmark technical support for assistance. When calling support, you will be asked for your model type and serial number. Thanks.
    Dec 15, 2010 | Lexmark X5650 All-in-One InkJet Printer
    My printer OCR command does not respond. The printer says it's connecting to the PC but after a short period reverts to standby.
    1. faq000559_002 When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with OCR or the Brother ControlCenter3, the text comes out as gibberish. This started after I installed Windows® XP Service Pack 2 (SP2). Why and what should I do?
    2. faq000093_012 What is MFL-Pro Suite Software?
    3. faq002613_000 When I try to scan to OCR I get an error message saying "This feature is not available because there is no OCR Software installed".
    4. faq002561_000 How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
    5. faq000562_002 When scanning to OCR from Brother Control Center3, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
    6. faq000563_002 When scanning to OCR from PaperPort® SE, the following error message appears: "System error incurred in external ink module EZText.g32. The OCR server is unable to process the document". I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
    7. faq002620_008 Windows® 7 Support Information
    Oct 26, 2010 | Brother DCP-330C All-In-One InkJet Printer
    How do I reset the message on Oce fx3000?
    open the front door and press clear. drum reset? should come up on screen
    Dec 31, 2009 | Office Equipment & Supplies
    Cheers.
    Mar 27, 2009 | Lexmark X2500 All-In-One Printer
    457 people viewed this question
    Marvin
    Marvin
