Washing Machines Logo
Aeg lavamat w1020
Just wanted to know how a lavamat 1020 conpairs to the oko lavamat 74620 as i am thinking about purchasing the 1020 i will have to part with my old 74620 unwillingly
Posted by islandlas on
2 Related Answers
Anonymous
  • 326 Answers
SOURCE: I need cogs for my aeg lavamat where i CAN GET IT?
you can get it at  www.repairclinic.com
Posted on May 06, 2009
Anonymous
  • 3917 Answers
SOURCE: AEG Washing machine Oko Lavamat
The C9 on some AEG LAVAMAT models like the 71400, 72600,74620, 86720 and possibly others, is the same as the above F9, and is usually MOTOR BRUSHES WORN OUT. After replacement, you will need to clear the fault indication held in the PROGRAMMER PCB logic: With the Switch in the OFF position - Press and hold PRE-WASH and SOAKING buttons in at the same time, then turn the control knob to Short Spin. Wait one or two seconds and all the indicators should illuminate. Then turn the control knob to OFF. All the indicators should go out. Then try and use your machine as normal. This should clear the C9 error code. If it does not -check there may be another fault present.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 29, 2011
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Hi can anyone help me please im looking for a user manual for an AEG oko lavamat 75620 washing machine
do google search for "user manual AEG oko lavamat 75620" on page 2 about 4th down you will see a pdf manual for your model ( it's the "update" model but they are virtually identical to use ) don't download straight away it's foreign but don't despair click the option Translate this page and you'll then download an english version of the standard commonly experienced when Nigerian or Ugandan ex govt ministers let you know, via email, of an opportunity to help them smuggle millions out of their respective countries. never-the-less you will be able to run your machine from it.
13helpful
AEG OKO LAVAMAT - BROKEN BOLT - WHAT DOES IT DO?
The bolt you described is indeed a transit bolt and should be removed. I believe that the current UK agents for aeg are service force. Check their website for your nearest branch.
Hope this helps & thanks for using Fixya
2helpful
6answers
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
10helpful
3answers
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Top Washing Machines Experts
Marvin
Marvin
W.L.
