Question about Pioneer AVIC-N2 Car DVD Player
AVIC N2 WONT READ MY NAV DISC,WHEN I PUSH MY MENU BUTTON IT SAYS INSERT APPROPRIATE DISC, NOT SURE WHAT DISC IT WHANTS
Posted by sdl9564 on
universalfoe
  • 34 Answers
The nav discs come in a set of two. Disc 1 and Disc 2. Insert disc 1 first, if unit does not respond or read nav disc, then you may have a bad copy of the nav disc or incorrect copy.
Posted on Aug 02, 2009
How do I set the clock?
To set the clock turn the unit on and hit the big blue nav/menu button on the tv , then touch settings on the screen , and then touch the time button . You should be able to figure it out from there . When done touch the back button . Or disconnect the power from the brain unit for a couple seconds then plug back in turn the head unit on and insert the map disc that comes with the stereo it will automaticlly run you through the clock setup
Jan 25, 2011 | Pioneer AVIC-N2 Car DVD Player
Reading error/Mechanism error
Did you try reseting your unit?
Jan 24, 2008 | Pioneer AVIC-N2 Car DVD Player
Avic-dvr150 setup disc needed
order one from pioneer that the only way to get them for the model unit you have
Jul 06, 2009 | Pioneer AVIC-N2 Car DVD Player
AVIC-N1 Mechanism Error
We can fix all AVIC N1 N2 N3 Problems at an affordable rate.
Please check out www.turbotunes.com
-Steve
Mar 24, 2009 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Disc reading error
Hi, please browse through my solutions. You will find your answer there. Good luck.
Dec 03, 2008 | Pioneer AVIC-N2 Car DVD Player
Avic n1
You need to get an up to date navi disc. There is a procedure to down grade it, so it would read the yellow disc. But it will mess up the unit if you do it wrong. Beside half of the current info won't be on the yellow disc anyway, because it is so out dated. Goodluck.
Nov 21, 2008 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Avic drv50
Do you have the right navi disc. Because once you upgrade to newer version then when you put in an older version it will tell you to insert the appropriate disc. You need to downgrade it if you want to go back to older versions. Let me know if you need help on how to downgrade. Goodluck.
Oct 18, 2008 | Pioneer AVIC-N2 Car DVD Player
Carrozzeria avic drv 250 problem
check out bootdisc.ru
I have the drv-250 and download the disk from here....works perfectly now
Jun 21, 2008 | Pioneer AVIC-N2 Car DVD Player
My AVIC 9 sat nav unit will not read the discs keeps showing message please insert appropriate disc, still plays other cd and dvd ok
Assuming you have the original navi disc, then your laser eye is either dirty or tired(out of alightment) from playing mp3 or copied disc. Buy a cd lens cleaner kit if that doesn't help then have someone who know how and have it re-align. Goodluck.
Apr 24, 2008 | Car Audio & Video
AVIC-N1 "disc read error"
The laser eye need to be re-align or clean up. If you are technical incline, then open it up and clean the laser eye and turn the mounting allen wrench nuts up a bit. If not have someone who knows do it. 'Cause there are alot of things can pop out of place when you opened it. Goodluck.
Mar 14, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-N2 Car DVD Player Logo
679 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
